FERRINO
FERRINO last won the day on June 4 2016
FERRINO had the most liked content!
1 Follower
    Sold Sliding Pillar 2B build - bought Locost
    Tony Edwards
    Rugby, Warwickshire
8,964 profile views
FERRINO's Achievements
Wheely good builder!
Wheely good builder! (4/6)
46
  1. Ah ok - I'm not a paying member anymore so probably can't do messaging anymore. No worries - Just drop me a txt to 07894 151757. Are you sure you want to drive all the way from Bolton to Rugby and back for some incredibly rusty bonnet parts though? Cheers Tony
  2. Hi - Yes you have just caught them in time. Was going to book a tip appt next week Drop me a message. I'm in Rugby, (5mins off Junction 1 M6) by the way. Cheers Tony
  3. Just bumping this back up again as the tip run is looming, so I'll be scrapping them fairly soon. Are either of these any use to anyone on here - or know anybody that might want them before I do? :- Located CV21 1JE.
  4. Hi Neil - What model do you have? If it's a 2B, I have a standard mild steel bonnet (hasn't been fitted but is rusty and needs shot blasting). Also got another one that's been cut at the scuttle and has been sprayed black quickly with rattle cans. Both are taking up space in the loft. Was planning to take them to the tip when the hysteria is over and we can finally doing normal things again. Cheers Tony
  5. FERRINO
    short sump
    I've got one on Ebay at the moment. Was a spare I kept from an unused engine :- https://www.ebay.co.uk/itm/Shortened-Pinto-Sump-Kit-Car-Westfield-Robin-Hood-Locost-Roadster-Caterham-Sierr/224139051875 Cheers Tony
  6. FERRINO
    2B
    Hi Ed - As mentioned above the much larger size of the 2B makes it impossible to buy GRP side panels/rear tub/bonnet etc off the shelf. I managed to fit GRP all round - except the bonnet - but it wasn't easy. The closest GRP bodied car in terms of size is the Haynes Roadster which plenty of places make bodywork for still. I bought a Roadster rear tub - cut it down the middle - extended it (60-70'ish mm from memory) - reconnected it with small aluminium box section top and bottom and made an infill section to cover the gap. This gives you proper 'flat' sides to which you can mount GRP rear wings - I used GBS Zero rear wings but my wheels were really wide. You can use normal width locost/roadster rear wings though. For the side panels - again Haynes Roadster is very close and almost does fit straight off the shelf. The 2B chassis is a little taller though (5-6mm only!), so I ended up having to cut the top and bottom return flanges almost fully off. You then have to use fixings in from the sides into the chassis tubes as obviously you don't have the top/btm to fix with anymore. You could bond them on though if you didn't want to have fixings showing on the sides - but then it's harder to remove them if you ever needed. For the bonnet - I couldn't get anything even close to fitting and had to resort to aluminium. Even then, there aren't any companies that do one 'off the shelf' and mine was just a lucky Ebay find. If you're handy with fabrication you could always have a go at rolling your own? Hope that helps anyway - and good luck with the rebuild! Cheers Tony
  7. Thanks for the nice comments chaps! Car is now sold and being collected later this afternoon. I had loads of offers through Ebay and txt - all of whom were offering the exact same amount (2k). I ended up getting a bit more than that - but unfortunately the value of things is set by the market. The plus side of not having to spend hours in the garage stripping stuff apart/dealing with postage/having little bits left over outweighs that though - so I'm happy it's going complete. Bit of sadness to see it go - but looking forward to the future hours of trying to get the basket case bike engined Locost sorted properly. At least the car is hopefully going to a good home. A guy from Kent (I think he's a mechanic or owns a garage?) is buying it for his Son as a project to cheer him up as he's had a bit of a rough time by the sounds of it. He appreciates the fact that it's a project car and will require plenty of tinkering and will have some issues to sort - so that is a big plus for me when selling something like this. The last thing you want is someone coming back to you every 5 minutes complaining about things etc. Cheers Tony
  8. Hi Martin - I'm in Rugby (CV21 1JE). I've got someone coming to view tomorrow night and someone else coming Wednesday - but if neither are interested for any reason I'll give you a shout. Cheers Tony
  9. Selling my unregistered sliding pillar build :- https://www.ebay.co.uk/itm/223903685166 Cheers Tony
  10. Now on Ebay - I kinda already know I'm going to end up having to break it . Bring forth all the Ebay weirdo's and total timewasters lol! :- https://www.ebay.co.uk/itm/223903685166
  11. If I end up breaking it down - then yes definitely wheels/tyres would be one of the items that would be sold as a set.
  12. Evening all, I've finally decided to give up on the Sliding pillar 2B build and have today bought a locost with a bike engine. The car is tatty and needs a fair bit of work to get it properly right - but at least its already road legal and Mot'd for some summer fun. :- I really enjoyed the test drive I was taken on today. Surprised how gentle quiet and pleasant a bike engine can be trundling around - that is until the taps are opened and then all hell breaks loose! Quite a different animal indeed then lol! So despite putting 7 years on and off into the build of my 2B - I'm going to be looking to move it on. I would love it if someone bought it complete and finished it. At a rough calc I reckon it would be worth at least £2500 broken down and sold as parts but that is such a ball ache to have to do so would love to sell complete of course. Do you reckon I could put this up for £2000-2500 as an unfinished project that starts/stops/steers/all electrics work and pretty much all parts to complete provided? Does anybody know anyone who might be looking? It's much more complete than this now - but it's one of the latest 'outside' pics I have:- Cheers Tony
  13. Also signed
  14. Hi Davo - It's difficult to tell from the pics, but are you sure that's a 2B? Is there a tubular chassis underneath that wide side panel? Cheers Tony
