Mot next week so I thought I'd check it over. My hazards are only working on near side. The indicators all work fine when used normally. With hazards only left ones work, but if I indicated right all hazards work fine. Have cleaned all contacts at the indicator stalk connector. Tried new relay. Checked earth's. I'm a bit stumped. They have been fine before. I'm thinking it may be the switch? Any ideas? Tia
Most likely to be the hazard switch, there's 2 switches in it that supply a feed to the LH and RH indicators when the hazards are switched on. You might be able to flush out the switch with some electrical cleaner.
Sorted! You spurred me on to take the switch apart. I was afraid of springs flying everywhere and making things worse. It was a right state in there. Gave it a good clean and all is well. Many thanks!
Oh! you just posted the fact it was fixed while I was writing this ..... so  no need to read it. (post deleted)
Edited by Sparepart
add
