cb750
1,428 -
16
Posts posted by cb750
I run a facet red top pump. You can hear it when you switch the ignition on and goes quieter when the carb float bowls have filled but you can still hear it humming before starting the engine. I wait until the pump goes quieter before starting so that I know that the carbs have the correct level fuel and the engine starts first time.
I was told by a supplier that the early red and silver top pumps would switch off completely when back pressure was sufficient but I don't know if that's correct.
I'm using these J & R driveshafts. If this is the same design as the ones that I bought, they are too large in diameter to pass though the hole in the swinging arm using the normal installation method. After discussions with the owner of J & R I had to take the outer joint off, put that into the hub from the inside, put the rest of the shaft into the diff and reconnect the joint. There's just enough room to do this. The owner said that he originally designed these for Westfields which don't have the hole size problem.
let us know how you get on.
Hi Duck, I'm interested in the pinto front oil seal carrier (the bit you can't identify) can you let me know how much you would want to post it please. I can pay you by PayPal or cheque.
Rob
I had exactly the same thing when I bought my car. Although it ran fine at low revs and gave no indication that there was a problem, it struggled to get passed 2500 rpm. Checked it over and found the following:
Valve clearances closed up with 2 cylinders having no clearance.
Spark plugs had never been changed, 1 had the tip missing and 2 had a ball of carbon on the end
Timing out of spec
ignition leads breaking down
I was amazed it ran at all! SO before you start pulling things apart I would recommend carrying out a full service and then go from there
Can you post a picture up so I can see what you are looking at as my 3A does not use extensions.
That's a slightly different one to the map shown on the Stoneleigh website. 73 is shown only as a small area on that one
If it is block 73 then that looks to be small!
Valvoline vr1 20w50. I understand that it has a high sulphur content that is good for cam protection.
I had straight tie bars on my 3A but replaced them with ones made from the ends of the antirollbar as the Duck said (thanks for the bar Stu). The straight bars restricted the turning circle due to my wider wheels and the Sierra based bars gave me a bit more clearance. With both set ups I had to fit rack stops to stop the wheels fouling but as I said, this is down to my wheels. I fitted a 50x25mm box section tube under the monocoque between the 2 tie bar box sections to spread the load.
I've got a 3A and mines comfortable. Have you got the shocks set too stiff and are you running the original anti-rollbar set up or changed to tie bars?
Taxed car Monday. Had a great ride out in the sunshine but don't think I'll be out again this week looking at the weather!
As richyb66 says, they are for the 2 side bolts at the front of the cam cover.
Is the pump installed correctly (it looks to be vertical)? Doesn't the R1 have the pump horizontal or am I thinking of another m/cycle?
My series 3 front top suspension "horns" are not like that, they are wider and cover the wishbones.
Looks great! I wrapped my sides and rear panel. As you say, it's straight forward enough, I did my 3A with the wheels etc still in place.
For known guaranteed quality items I use a local engineering fasteners suppliers as they will not deal in poor quality items for safety reasons. I've also used Namrick Ltd for UNF and odd size metric and found their service excellent. For stainless fasteners where I'm not too bothered as I use them mainly for cosmetic purposes I use eBay, someone like Kay's or bolt-world.
Arial Golden Arrow (Super Sport)? Looks really nice, one of my friends had one in the day. He loved laying down a smoke screen from the exhausts!
As this has an electric choke, has it been wired in correctly and does it work? I also agree about the cam, when I bought my engine it wouldn't run properly. I found that it had been fitted with a competition Rally cam which was never designed for road use. I changed it and the engine runs great.
It always happens! Had a clear out and took one to the tip the other day otherwise you could have had it.
Yes, me too. Over 100 cars and 15 bikes! As regards the Borgward, if it was in good condition probably about £8-10K. The coupes are well over the £20K mark with the cabriolets way over that.
Yes, it's a 1958 Isabella TS. Bought it for £20 in 1965. Converted it to 12 volt lighting but kept 6 volt starter, instruments and the valve radio. Changed the column gear change to floor change when I found a German police conversion in Wolverhampton of all places. I repainted it with Tekaloid coach enamel by hand. I enjoyed it so much I kept it for 13 years.
Rob
Seems to work ok from iPad. Not done with other hosting software though. Still appears to have the file size limitations as before.
That's my 2nd Car many, many moons ago!
The fun starts here - anyone know this car?
in Build Threads
Mine's the same design as that one. I think it's based on the VW Polo. Being an aluminium radiator I was told by the supplier (Radtec) to mount it on flexible rubber bobbin mounts and to only use the old style antifreeze with it. Apparently they have had failures at the matrix joints with the newer antifreezes
