jaimo
Everything posted by jaimo
  1. jaimo
    Caravan
    Tested car on anorther caravan all good and anorther car on my van no good Factory fitted and all working Fitted loads of towbars over years and yes know all about telling ecu or by pass Had caravan nearly 10 yr and had this problem on van with last car but only just got round to sorting it Cant get a wiring diagram so just going to have to trace back i think very complcated van for age
  2. jaimo
    Caravan
    Charger working Its 2018 mitsubishi outlander The car electrics are working and getting power into van and to control panel and new switch from there pass
  3. jaimo
    Caravan
    I checked bob mains into charger 12v out so you are correct will have to delph deeper
  4. jaimo
    Caravan
    I know its not a kit but is anyone any good with caravan electrics Basicaly when pluged into mains it charges battery at 13.5v so perfect but doesnt doesnt stop charging and cooks battery and When plugged into car it doesnt charge battery at all yet got power to the 2 relays swopped them for new and no change even bought new switch control panel no change Does the car power go through the charger
  5. jaimo
    Pre Ignition
    I will have a look chris
  6. jaimo
    Pre Ignition
    How do you input the values chris
  7. jaimo
    Bmw Z4
    Kit is running brill now just wants ecu and carbs setting tweaking apart from that its great
  8. jaimo
    Pre Ignition
    Getting some pinking preignition Has anyone got a map for megajolt 2.0 pinto with r1 carbs I got the software on laptop and megajolt connects and can see map and setting etc but how do you change map do you have to input values into grid manually
  9. jaimo
    Bmw Z4
    Its a friend of a friend and he called round last night saw kit and wants to swap oh and its a 2 owner car his now and his mums before from new I took it out and although really nice didnt feel as fun as kit
  10. jaimo
    Bmw Z4
    Been offered a 2005 bmw z4 2.5 in absolute mint condition 1 owner car What are these like Anyone had or got one
  11. jaimo
    Bits For Hood 2B Please
    Wood cut your own and cover it easily done Not sure what the rear suspension looks like might have some spax if you get pic and measurements up
  12. jaimo
    Zetec Rwd Parts
    Exhaust needed dean let me know mate Got carbs r1 just need manifold
  13. jaimo
    Zetec Rwd Parts
    Bike carbs for now dean
  14. jaimo
    Zetec Rwd Parts
    Pm u chris
  15. jaimo
    Zetec Rwd Parts
    What flywheel chris
  16. jaimo
    Zetec Rwd Parts
    Changing pinto out Going for pinto clutch new flywheel think going to need water rail which one is best I like duratec would be better to keep exhaust same side but the belhousing etc and finding a good engine at right money
  17. jaimo
    Zetec Rwd Parts
    As above what you got Getting things ready for winter I have got Megajolt engine mounts Need everything else
  18. Hope these help
  19. http://www.rhocar.org/index.php?showtopic=20136
  20. http://www.rhocar.org/index.php?showtopic=30768
  21. jaimo
    Exmo Front Struts?
    Steamer on here does them if he still does do them
  22. jaimo
    Exmo Front Struts?
    I fitted the mod made by steamer so far so good as replaces bearing
  23. jaimo
    Exmo Front Struts?
    The top mount if i understand correctly what you ask is a big washer basically top of spring
  24. Is anyone interested in this
