Everything posted by Jonty Wild
- Accelerator Cable plus another query
Off the car, measured and a new one found of the right length and looks like the right carb fitting and ordered - should be right. Thanks all for the advice. Hopefully back on the road for the weekend. Must improve the angle by which it left the pedal and entered a guide tube as that is why it frayed and broke - behind a cowling covering the pedal hinges and brake cylinder, so not normally visible. I'd really like to get a spare clutch cable, but I expect it would be the same advice, i.e. get it off and measure it?
Robin Hoods 2B Plus - Ford Sierra based 2 litre Pinto: My accelerator cable snapped this morning on an early morning run, so does anyone know what accelerator cable is likely to be fitted to my 2B (Sierra?) or is it a case of taking it off and measuring it and finding a supplier? Either way any recommendations for a supplier - quite urgent only because I don't want to miss this beautiful weather . . . . . what a pleasant way of seeing the countryside limping back on idle in first or second😁 Also an interesting aside, when I was parked, engine running, hazards on, the engine wouldn't switch off until I stopped the hazards first. Any ideas why. The hazards worked fine with the engine off or on.
I don't think I received it, what would have been in the 'subject' or 'from' line and I will have another look.
- GBS Zero Rescue
Sierra Ignition Switch Power cuts to Aux 1 on Crank
Yes you are correct there is no more heat going in, but equally no air cooling. I have had several cars in the past, e.g. Ford Capri, Ford Orion and I think my Audi Coupes (probably others too) plus my Robin Hood 2B, when the fans often came/come on a few seconds or even minutes after the engine had been turned off - sometimes several times. This suggests that the temperature at the switch had risen enough to turn the fan on again, and I have certainly had cars that boiled over after stopping and, although running hot, not while running (usually because of a fault).
Err it could be a problem because if the coolant isn't circulating the engine could continue to get hotter without the fan going, Are you sure that isn't working? i.e. does it come back on at all, even say after a couple of minutes?
The Motorist Kit Cars & Modified - 9th August 2025
No problem, welcome.
Track Rod Ends Robin Hood 2B Plus
Just finishing off chat (probably!): So I went for tracking and asked for between 1 and 2mm toe in. They said we only work in degrees and minutes now. . . . . doh! I couldn't convert that without a tape measure and pen and paper and some time, so I asked them to aim for a smidgin or a tad of toe in "as officially recommended by the experts at the club", which they seemed happy with. I have ended up with 1 degree 58 minutes. I have to say that it is much better than toe out (no surprise there!), but if I am honest, I am not sure that it is better than it was before I replaced the steering gaiters and track rod rubber boot, but is it as good . . . . . umm . . . . . still thinking. It almost sailed through the MOT . . . . . almost! Having checked the car over beforehand . . . . all the normal stuff - lights, indicates, wipers, tyre pressures etc., oh and the horn. The latter several times, and it was definitely working when I went for the above tracking (Sat), driving to the MOT (Mon) not a peep! So obviously it failed on that, despite me desperate looking for a loose wire, bad earth that I could fixed in the 5 minutes before the MOT. No luck, so obviously it failed on that. I have not got a sound out of the horn when testing it directly on the battery, so waiting for a new one. Could be worse I suppose, but b****y annoying. Hurry up Amazon. Beep, beep!
I think it it is a wee bit more than a smidgen.
Strange noise - RH 2B? - identifying just one.
Thanks Spannerman, that is interesting and logical when I think about it. The noise stopped later the day I heard it for the first (only) time, maybe after I drove it and used the indicators. If it happens again I will follow you advice straightaway. Thanks
I thought maybe a tad.
Just to finish this one off. I ordered one track rod end for an Escort - definitely wrong as it had no offset - there are loads like that. Found some offset ones that look right, but most have no measurements, some are much longer and I don't think these would fit. Found some Sierra ones, that are indeed offset but they don't look like the ones on my car as they have a have triangle on front of each - I have a sneaking suspicion that these would fit, so I was holding these as a reserve. Found one described as for any Sierra based kit car and looked perfect, but the wrong side, so I rang them and asked of they had the other side, they pointed me to another which looked completely different. I pointed that out and they said the picture was wrong on the one that looked right . . . . damn! Found others that look the same, but although listed for various Fords are not listed as for a Sierra - I have a sneaking suspicion that these would fit too. By this time I had followed Foz's advice (above) and ordered some Sierra replacement rubbers and have fitted one. I think it would have been better if it had been a slightly tighter fit, but I think that it's done the job and I will just monitor it periodically. Tracking tomorrow, just got to decide how much toe in to ask for. Then MOT Monday.
Just Googled the rubbers, loads around. I wish I had measured it while it was off the car!
Thanks for the info I am thinking Sierra too now, but there seem to be several versions so I still need to be careful when ordering. Very few show the joint from above which would really help! I wasn't aware that you could just get the rubber, that is all I need really - it has split might have been me getting it apart to replace the steering gaiters, not sure. Any ideas where I could just get the rubber from?
I need a pair, or at least, an offside track rod end. My understanding is that the rack on my car is a Ford Escort, not Sierra - maybe they all were? Certainly the steering rack gaiters were ordered for an Escort and they matched and fitted. My existing tie road ends are sided - see photos of the o/side - the nearside is a mirror image. I ordered a pair of Quinton Hazel items for an Escort (or at least I thought I did as there were 2 in every picture!). Only one has arrived and clearly it intended to fit either side and doesn't look like to would my car any way. I Googled the number on the item, but didn't get any hits. Can anyone advise on a part number or source or the car it would have come from? Could it be that the track rod ends are Sierra fitted on to an Escort rack? Looking at images on line perhaps I should add that mine have a tapered end that fits into the hub carrier. Some of those I have seen on line don't appear have that.
Wheel Alignment 2B+
Thanks. It will be interesting to know what is it now, and I am not sure that I want to change it too much anyway.
Wheel Alignment 2B+
Indicator switch changed and steering gaiters replaced, now ready for MOT - Yippee . . . . fingers now crossed! Although, there were no previous problems (e.g. steering, pulling either way or braking angled), and I have put the tie-rods back to their previously marked positions. I think that I should get the front wheel alignment checked. Does anyone know what the toe-in should be? I presume that I will need to tell them what I want the readings to be. The Sierra donor would be '2.0 mm (0.08 in) ± 1.0 mm (0.04 in) toe-in', but that would be a much heavier car. Visually there does look to be a toe-in, obviously that is unreliable and anyway I reserve judgement as haven't driven it yet (I finished the job a bit late and it is actually raining this morning . . . shock, horror!). Out or curiosity any comments on cant angle? On a completely separate issue, but also out of curiosity I recently experimented with increasing the tyre pressures, I run at (18 to 20 lbf/in2) to 25+, the ride was absolutely terrible and my confidence in the handling nose dived. I hadn't realise what difference that would make - I just provide this information for interest.
East England meets for August
I would love to join you on the 20th but unfortunately I am leading a walking group that day, also as I am about to change the steering gaiters pre-MOT, so I can't be sure the car will be drivable - it should be of course, as it shouldn't take long, but you never know. If I need other bits (e.g. tie rod ball joint) I will have to find and order them.
I will next time (if/when) it happens, but I think that will definitely stop because it must be electrical, unless there is something wind up that mice are playing with. I don't have a live by pass as far as I know. Surely all green eyed monsters have long legs so at least they wouldn't be able to drive it!
Welcome to New Members
I think would be sensible (if not already in place) for members to have a card or details on a window sticker or their membership card, which they pass on or leave in/on the car, if they sell it. Obviously (probably) only when reprints need to be done.
Staffordshire area meet 31/07/2025
Congratulations
