speedtripledan
6,546 -
104
beams are accross the drive and set a buzzer off which people can hear that in itself usually puts people off because they then know they have been spotted + if you are in you can look out they also set the cams recording an event so you can review if anyone has been nosing around, having had 5 cars broke into i got a bit sick of it... As for the car they would have to drive it without a steering wheel ( quick release) best anti theft device for an open top i can think of. £26 ebay usa and a bit of fettling...
plenty of people are jealous etc just sounds like the sort near you are the type that would vandalise or nick it rather than than get off there ass and achive it for themselves. A good alarm / laser parameter beams / cctv protect my garage and i live in a nice area... main reason being i cannot get more than £5000 insurance cover for the contents of the garage good job i,m a security engineer.. Dan
cat and fiddle v early sun morning anybody up for a run ? starting matlock bath. Dan
I'm a bit puzzled at what seems to be the current value of 2b,s etc they all seem to be around £3000 mark Rather than spending all that time effort and money it would seem better to buy one that's on the road with all the Iva hassle done and refinish it to your own taste? i,m thinking of this now to do a v8 / v6 conversion to rather than taking mine off the road.. Dan
my mum used to have a problem with supermarket fuel in her pinto sierra yrs ago best thing to do drain it out and fill up with your regular fuel Dan
oregan atc 3k is for sale boxed with 4 gb memory card look up the spec water proof shock proof etc £70 Dan Last chance for a bargin £60 + post also now going on ebay sold on ebay £64.55...
where is this usualy fed from as ive noticed at night when i have all my lights on i get the ocassional stutter which never happens without lights so there must be a voltage / current drop to the coil i will just wire a new feed and ditch the old. one not tested yet just curious before i have a go Cheers Dan
I had probs with some of my warning lights at one point main problem i found was the left hand stalk on the steering was the fault dissconnected it and all was well replaced been fine ever sense this could just have been a thing to my car thou as the loom is a bit s**t. I,ve also increased the diameter of my bat cables etc this also helped matters.. Dan
as per colin (solcol) will be there if it ain,t raining ......
i have the oregon atc3000 its only real downfall is the electronic iris it closes up at a hint of sunlight which makes the pics go black and the mic is a waste of time in a 7(I switch it off) if you use it in a tintop its fine. i think these were more aimed at mountain bikers / canoes etc but for the money you would be hard pushed to find anything better. when i have the money i,m going to get a portable 2 ch dvr with flash memory and use a high res cctv cam already experimented with a 520tvl high res cam and you get top gear like quality its just the dvrs are a bit expensive at the moment you can buy decent packages but you have to part with decent money..... as a hoodie i,m always trying to find the cheap alternative try speedtripledan channel on youtube if you want an idea of the oregan quality some is ok some a bit dark ie barkstone, of 2 hrs recording that was the best i could find all the rest was like it had been filmed at nght. Dan ps my oregan atc 3k is for sale £70 boxed with 4 gb memory card
To get the best out of it you will need a new dizzy or mod your own the advance needs to be 12deg at 1000rpm to 34deg at 5000rpm i used a bestek set up for this complete ignition system only requires +feed to coil and a grd to chassis £180 on ebay also you may want to consider that there is nowhere for the crankcase to vent other than atmosphere so i used a catch tank and vented that to the back of the car i hate the smell of oil ! also silly things like how you are connecting the throttle cable to the existing pedal etc an extra 6bhp was gained by the use of a vernier cam pulley, the car will also run hotter as a result of the power increase i had to improve my cooling by putting more vents into the engine bay etc a bit of effort and time required but well worth it I dropped lucky with a dyno but the car is much better now having done all this all in cost me the the wrong end of £600 (160 of that was the dyno) and i already had the carbs good luck Dan
It is easy to fit but there are other bits and bobs required i did mine and its the best thing i have ever done to the car. main thing is to get them dyno set up by someone who knows what they are doing.. Dan
Far sale 2.0L pinto with injected head and 205 bottom end. was taken out of my hood running fine didn't smoke, only problem is the cam shaft lobes are worn. this is just the engine no injection or carbs or dizzy Dry stored on engine stand for last 2 years was keeping as spare but want the space now £75 collected Dan
Is there going to be a meet next weds ? If there is i will be along with colin weather pending of coarse Dan
Tell him to f! off he is trying to fleece you, sold as seen his problem he is just one of a growing number of idiots out there Dan
there are pics on the net of him he is in a bad way, sedated until tomorrow they say he has a life threating condition as a result of a skull fracture with henry surtes last week and now massa and that westy crash just shows how bl**dy dangereous it really is racing/driving our cars about! Dan
There are some great pics on there put me down for a copy when its done if for no other reason then the charitys you are supporting Dan
have you thought of using bestek £180 all in new dizzy control module and coil simple to fit 1 12 v + to coil and and 1 chassis grd i have this and it works a treat Dan
now't to be sorry about your car is chuffing quick you were hiting 90 where i could only hit 70 your car is wicked mate made me more determined to build a mev rocket with some serious bhp! Dan
Has anyone got any pics of my car in action from barkstone no.32/36 blue 2B ? Dan
pintos and the like were used because they are from the last cheap mass produced rearwheel drive cars Sierras and before that mk2 escorts etc might not be the best nowadays but they are still quick in the right tune and fairly bomb proof some do seem to favor the vauxhall lumps but i still prefer fords, zetec will be the next one in mine Goodluck Dan
didn't get meny pics but did put a vid on youtube wasn't my quickest lap had to sit a while on the line while they cleared someone out of the tyre wall. Dan
you would get more power by going down the bike carb route as i have done about 30bhp,mild cams don,t give much on there own seems about 7hp ish Dan
Great day out well pleased with getting my bike carb pinto 2b in the 58's, 3secs better than last year ! 10hp per second (30hp up on last year) thought my brother did well also never have'n driven the car before and got under 1m1sec going to make a new exhaust and start on some other track days Dan
what a brill day no rain ! a few crashes and offs but no injurys! thanks for organizing it again john put me down for next time....... i thought id post the lap times.. Dan
