fry61
Everything posted by fry61
  1. fry61
    Suspension
    Hi, on my 2B+ I have 8" 300lb springs on the front & 10" 300lb springs on the back --all with Gaz shocks--hope that helps or I'm wrong way round.
  2. Once again Ferrari show that they will do any-thing to win--on the track--in the pits--in the courts. The Shoemaker said years ago a win is a win--how is soon forgotten by most.
  3. fry61
    Seatbelts
    Hi all, would like to fit inertia reel belts to our 2B so my little wife & I can swap drivers with-out hassle. What height must the top swivel mount be? (reel bolted to floor chassis tube) Can I put a half-round bar up inside the vertical of the roll-over tube & threaded for the mounting bolt. What is the 3rd dimension for the reference block in the seat--136 x 53 x ? is 450mm the minimum mount height above this block or can the swivel mount be higher? Thanks in advance for valued replies. Regards Bob.
  4. fry61
    On The Scrounge
    Hi Keith, thanks for the info; too heavy for my use but thanks for posting.
  5. fry61
    On The Scrounge
    Hi keith, can you tell me what thickness & finish on your S/Steel? Also where abouts are you based. Cheers Bob
  6. fry61
    Southern Hoods
    WE will be there with Wendy & Vic early on Sunday, what can we bring along to help dress-up our RHOCAR pitch? --Tables & chairs; parachute tent,--are we allowed to fix (tent pegs) anything to the ground? If we camp are we allowed to use a barbie for break-fast, cheers Malcolm see you Sunday week in glorious sun-shine (we've used up all the wet weather on our home BBQ's) Regards Bob & Sylvia.
  7. fry61
    Petitions
    Asteroid "Apophis" (Evil Egyptian God) first prediction Earth strike would be April 13 2029 (sorry I said 2025 from memory in ealier post) but after re-calculation this date changed to a near miss event (just brushing the outer atmosphere) It crosses earth path again on Easter Sunday 2036 when a strike is a slender possibility---- so enjoy while you can.
  8. fry61
    Leaning To The Left
    Are not the rear arms rubber mounted & therefor bolted up tight-- vertical movement causes rubber to twist in itself so can't seize only fail altogether? If front wish-bones are seized sugest adding a grease nipple to the inner side of the bush tube -- pump full of grease which will force the plastic bushes out (if wish-bone is off car) or free-off bearing. The inner tubes which lock the bone to the chassis are mild steel & likely to rust if installed "dry". Please shoot me down rapidly if you dis-agree!!
  9. Realy old one's amoungst us will remember BELCO brushing cellulose (?) --paint it on --several thick coats-- then wet & dry--then cutting compound-- then T cut-- then polish-- to find you've rubbed though the finish.
  10. fry61
    Petitions
    The asteroid due to strike in 2025 or 2036 will totally mess-up any CO2 savings --so carry on burning fuel & rubber while you can--no worries!!!
  11. fry61
    Suspension
    Chris, where are you measuring springs & dampers from?, is it to centres of damper mounting holes or length of spring only-- does it make a difference what make- mine are Gas shocks & 300lb springs all round, thanks in advance.
  12. fry61
    Wanted 2/3hp Inverta
    It's easy to convert the motor to 1phase running provided all 6 ends from the windings are accessible-- the motor needs to be connected in DELTA-- A1 toC2-- A2 to B1-- B2 to C1 connect supply (230 volt ) across A1 - A2 & a new capacitor (25-30 microFarad) connected across B1 - B2 , cost about £15. The main down-side is you can't use your existing switch-gear & the power will be down somewhat.
