404 -
Everything posted by ZeroKnowledge
using fazer 1000 carbs with megajolt ignition
I have a DOHC with MT75 gbox in my zero, dont know if a type 9 matches, I got a 4-1 manifold from the guys at Robin Hood, £200 delivered. give them a ring and tell them what its for.
Hi Michael well done mate ,good to see your on the road, must be a great feeling. Cheers Paul
Hi Steve I have the MT75 (not 4x4) in my zero with 2l DOHC, Iam not home till next saturday so if you want to come over and have butchers no problem.
See photo of spare I have, as long as you have removed the pin from lowest hole you can grip bottom of gear lever with mole grips and twist back and forth to release it, also spray it with some WD40. Mine was well rusted so took a while to release it Cheers Paul
this is where mine is at present,it was put there by previous owner but I want to shift it to under water pump. can I use a ready made bracket or do I need to fabricate one any photos anyone has of alt under wpump would be good to see cheers Paul
Hi John Yes mine are e marked. do a search on ebay for: ring m-lite them put tick in the box: Include title and description then hit search button 4 sellers on at present Photo of M-lites also recently seen a Zero with normal single bulb repeaters on cycle wings that went through IVA ok (failed on other items) Cheers Paul
I have just bought some Ring M-Lites from ebay £6 inc P&P, not fitted yet as still building. They have adhesive backing and can be bent slightly to fix on curved surfaces 2 banks of 8 leds in each lamp very bright cheers Paul
I have an unused ready built Megajolt V4 TPS version if your interested Complete with: Serial cable to connect to PC (adapter required for USB) Fully wired molex with 30cm of cable Installation CD (written by Martin Millener) Mounting Brackets (not shown in photo) Megajolt decal This was built and tested by Martin Millener. Price is £130 which includes P&P with Royal Mail next day delivery before 1pm Cheers Paul
Exhaust has now been sold Cheers
Hi Trackerjack Where in the country are you
Any offers, dont be shy
thanks for info I ve seen the fleabay quickshifts etc(£46 seems alot for 3" of metal with no moving parts), but as Iam tight as a knats chuff I was hoping someone had one lying around for used prices.
Hi Rob I am also building a Zero with a DOHC engine and a spare engine would be great, unfortunately I live 370 miles away in Newcastle and I dont think the car springs would be happy. Any van drivers out there that goes between Worthing and Newcastle that could collect for much cheapness. Cheers Paul PS a photo of my zero at present
Hi Bill just been in garage and taken these photos of my zero pedals accelerator cable isnt connect yet, cant tell you how they were put together as they were in when i bought it cheers Paul
Ford DOHC 8v Exhaust Manifold 4 into 1, see photos its in excellent condition, looks like a Robin Hood S/Steel jobbie probably suit a 2B or similar. yours for £95+ del I live 6 miles north of Newcastle on Tyne, you could collect or I my be able to sort out free delivery to a motorway junction (my brother is a lorry driver) any questions please ask Cheers Paul
I now have a gearstick, just need a quickshift now, hav a rummage in your garage n sheds, Cheers Paul
Sounds like a good reason to leave work early tomorrow
my kit is part built, its got a dohc 8v EFI with standard ecu etc from a sierra. I have a set of R1 carbs (spaced and setup for this engine) with alloy manifold but I dont have clue how to fit them Where do fuel lines, vacuum and electrics go? Do I need a fuel return to tank? Do carbs need to be at an angle? Can I use them with the original ecu? Is there anyone out there that can help !!!!! Please!!!!!!!!!!!!
I hav just changed to talktalk essentials package, upto 8meg download speed -40 gig a month limit -free wireless router -free local calls inc surrounding area codes 24/7 -free evening and weekend calls -line rental included all for £17.43 the switchover from orange was spot on, broadband was only off for about an hour
like to see the pics, did you fix the centre and wing mirrors to it ? Paul
Hi Simon As Iam on tight budget, as usual, i want to see if i can use as much as poss of the kit that i already have Paul
Hi Bone How much do you want for it?? I will at Newark for a couple of hours on saturday (dont know exact time) as I am calling in enroute to a weeks camping in Cornwall Cheers Paul
Hi All Newbie member, newbie builder, I have just bought a part built Zero from a private seller, complete with donor vin plate and V5. Yellow GRP with ally panels It has the following spec and I would welcome any thoughts and opinions. Fitted: Ford 2 litre Dohc 8v non cat- head skimmed and polished MT75 gearbox Diff- dont know ratio- donor was a `92 Sierra GT Adj Gaz allround Acewell digi dash GBS supplied rad & fan To be fitted: R1 bike carbs with alloy inlet manifold Exhaust - need to source a manifold Aeroscreen- need to source If anyone has good or bad points I would love to hear them Cheers Paul
