Redspec
Content Count
790 -
2
Redspec last won the day on August 24 2013
Redspec had the most liked content!
16 GoodAbout Redspec
Rank
Are we there yet
- Birthday 01/12/1961
Car type
Superspec Rover 2.0 + Zero in bits
Full name
Steve Cochrane
Contact Methods
Website URL
http://
Gender
Location
Co. Durham
Have a look at this old thread for info
What I should have said is it won't be a straight swop - different MT75 boxes. Re drill the fly wheel for a ford 2.0 DOHC cover plate (it's deeper and designed for a cable clutch) and fit a DOHC clutch. While the box is out change the spigot bearing for one that fits correctly - either a new bush or I think someone sleeved a ford one to fit. Then change out the thrust bearing, the 2.0 DOHC one will now fit as the cover plate is deeper and does away with the need for the bodged up one if you move the fork pivot point forward (done right this will also get rid of the fork rattle). As a la
I think the superspec box is an MT75 V6 LHD box
As Alan say's you want the 420 sump, the one I got was pressed steel not alloy so they must have manufactured both. An old sump thread:- http://www.rhocar.org/index.php?showtopic=21990&st=0&p=174462&hl=sump&fromsearch=1entry174462
Some bed time reading for you http://www.rhocar.org/index.php?showtopic=26387&hl=clutch The chatter / rattle is because the pivot end of the fork is held between 2 nylock nuts (one of them fitted the wrong way) Fitting a light spring to the clutch arm to keep the release bearing in contact with the cover plate helps alot with the noise
Saw this thread and thought I would have a look - Channel 240 not supported channel 71 some other stuff on, re tuned the TV using auto tune, YES YES YES channel 71 is now Motors tv.
Not been on for a few years http://www.rhocar.org/index.php?showuser=1220
Good Idea and yes I have one of these as well.
Use caution if using silicone near the lambda sensor it can poison them. http://www.ceradexproduct.com/techniquedetails.asp?id=12&edition=2 .Symptom of Poisoned or Damaged Sensors -Lead Poisoning Lead composite in the fuel may damage casing body as well as ceramic element inside. Immediate action to replace sensor and use only lead free fuels. -Excessive Carbon / Soot Deposits Soot produced by incomplete combustion of oil may cause blockage of frontal protection tube which lead to unstable and incorrect response time. Immediate action to replace sensor. -Silicone Poisoning
It Is the same, and your English is ok it's your Scottish that needs work
Posting this in chit chat so non-members can see the post as they can't see posts in members benifits. Used them again yesterday, must have saved £70.00 + this year well worth the £15.00 membership for this reason alone. Printed off the account number and sellotaped it to the back of my membership card, just handed him my card and said it's on this account - worked a treat.
New a girl with a hips like that once, oooh the memory's, VERY NICE
Upload them to photobucket and cut and paste the 'img' link into your post HTH Steve
