ok, car is running like SHt, thought it was my carbs but all appears ok, but when i remove nubmer 3 ignition lead there is no change to the engine running where there is on the others.I i checked that i had spark through the lead at the plug end by eathing it, Plenty of spark! changed the plug (Bound to be that) No still the same. used my timong light to see if that would register with lead attached to plug and nothing.
Took the rocker cover off to check rocker arm all looks fine.Checked that air was being drawn into number 3 at the carb and sucking just as mutch as the others. Did a compression test go 11.2bar not bad for an old motor! so i beleive i have ruled out the plug, leads, rocker, valves (would not suck and blow, pardon the expression)and carbs.
so why is she not running right???
HELP!!!!! I WANT TO GO TO STAFFORD!!!
thanks keith
