2,374 -
6
Posts posted by stevedohc2b
Ken
the rack may not fit your car as the rear hoop is different to a normal 2b ie it is wider so wheel sits lower
Stephen
Bob try http://www.wickes.co.uk/Wickes-Solder-Ring-Imperial-Metric-Adaptor-12-x-15mm/p/194626
solder
it
Stephen
If at work all day get AA or RAC out
if you dont have a test meter to check charge.
Or pop out lunch time and get one then a new battery if needed.
then safe drive home in the sun
Stephen
If the temp sender from the pinto worked can you not fit that into the zetec?
Yes single wire from top of tank is the sender.
The fuel gauge issue should not be related to the engine change, is the tank earthed, is there continuity from sender to gauge, is the float actually moving in the tank seen one jammed against side of tank before. Can you get the sender out to see or jack up one side of car to see if it changes?
+1 for all jet said
Take temp sender from pinto or a new one from Ford they are col coded.
Stephen
Thanks Bob and Mo
Great weekend good company great weather
Thanks for putting us up or ( putting up with us )
Stephen & Lesley
John
Try blowing tire's up that was a help i think for sva
Stephen
The dohc that ken has has different roll bar and mounts for suspension.
i am sure they could have don it that way the wheels woud fit better in the arches.
Stephen
Ian I Thought you had fixed most of it.
Stephen
Sad day Ian
I hate to suggest this, but could it have been nicked!!
Do kids still live at home with a car to feed.
Stephen
Are you taking up hairdressing Ian
Beat me to it
The Honda 2000 or Nissan
Would have been nicer for Ian but could make a nice next kit build as well has red interior like a Ferrari.
Stephen
Glad you fixed it well done for not giving up
Stephen
Richard
more room in my 2B
i think so just practice on this one :-)
Stephen
Bob and an air display http://john-hallett.co.uk/Blog/wp-content/uploads/2015/05/20150524-prescott-6.jpg
not my pic i felt dizzy just watching, his antics fab.
Stephen
Thanks Bob and Mo for a great weekend some pic's of the weekend
http://s119.photobuc...Bleu 2015/story
Stephen
well i have just been and had a play with my bigger knob and i have to say it is lot better, it find the slot very nicely now, what a difference those 3" have made...
But do you have brakes now ?
Stephen
Bob what have you been designing on the paper on table ?
Stephen
Hum intresting
Now Sold
- 2
Plugs out will keep them dry as well modern plugs don't like getting wet . Could try turning over with no fuel pump to check oil pre sure , first if plugs hard to get out? Then when oil pressure ok cone the fuel pump prime rail switching ignition on and off a few times.Then go for it.
Big smiles
Stephen
Hope Lloyd goes well John good to meet you last W/East
Stephenl
Excessively Loud Fuel Pump
in Driving
I mounted mine using a home made Big P clip lined with rubber.
or a nice new one http://www.ebay.co.uk/itm/52mm-ID-Fuel-Pump-Bracket-Anodised-single-Billet-Aluminium-Filter-Clamp-Cradle/151206843144?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20141212152715%26meid%3D27e9c70db459424cb98661d87939b527%26pid%3D100338%26rk%3D5%26rkt%3D27%26sd%3D130806621704
Stephen
