51 -
Everything posted by churchy
Thank you gentlemen, I shall wait until I have wired that ignition light and let you know how I get on. Very much appreciate your input. Cheers andy
Car stopped charging while out on a run, I managed to get home but when I checked voltage across battery without car running and with the car running was the same, 12.35 volts. To lazy to check wiring I ordered a new alternator, fast forward 3 days and in the garage with the new alternator fitted and checking voltage across battery to find exactly the same readings. I walked back into the kitchen because everything looks better with a cup of tea, 15 minutes later when I started checking wiring. I found a connector at the alternator end burned out as the wire had come loose. Great I thought easy but being the person I am and 3 years ago I completely rewired the car with a gbs wiring harness but that harness does not cover the alternator wiring, so I thought lets rewire the alternator wiring and be done with it. Now I'm running a pinto engine with a bosch alternator. On the bosch are 3 connectors two large and 1 small. One large connector went straight to the battery live the other large connector went to my kill switch, so when the key is connected it goes straight to the battery. The little connector goes to my warning battery charging light but I haven't connected this yet as I'm waiting for a 86 ohm resistor to put in line before it goes to the warning lights as l have smith flight dials and this is what they say, this light wasn't connected before but as I am rewiring I wanted the light to work. All excited turn the key on stared the car checked the battery and went to make a cuppa as things always look better after a cuppa. Still 12.56 volts with car running and the voltage drops to 12.34 volts with lights on so not charging. After a lot of swearing I check the two large connectors when unplugged from alternator, I have continually across both to the battery and also 12 volts with battery connected, the alternator has a good earth back to the battery as I checked continually. Last chance I put the old alternator back on with the same reading the voltage is the same with car running as not. Sorry for the long description but my question is have I made a school boy error or are both alternators faulty. Any help gratefully received as I'm all tea out. Cheers andy
Hi, I have a pinto running a oil temp gauge that the sender unit is in the oil sump plug, my gauge is a smiths flight with the correct sender unit, the sender unit is smaller than the plug in the sump so I use a brass bush to the correct size and using brass I have a good contact to earth. On the oil system I have a thermostatic controled take off unit from the oil filter that opens at 70 degrees to allow the oil to flow to a air oil cooler at the front of the car, this oil cooler does not have a fan connected to it, the oil cooler only cools when the car is moving,my temp gauge runs around 70 to 80 degrees on a cool day and may reach 80 to 90 degrees on a hot sunny day, 25 to 30 degrees air temp, hope this helps.
Thank you guys, it is great to know what I have to do and I best way to tackle it, the pictures are great and it just goes to show how important this club is, the wealth of knowledge and everyone's willing to give advice is tremendous and I am so grateful. I will keep you up to date with my progress and thank you again
Thank you guys, so once I have removed the nuts the threaded bar should knock out, then once removed the tube with the bushes should lift out so I can get to the bushes if I understand correctly
Hi guys, need some advice before tackling my next job. On the drivers side I have about 1/4" play on this bush at the back that I have circled in pink, now I think there is a Bush the other side of this threaded bar/ bolt, it looks like it doesn't travel all the way through so another bush on the front, has anybody tackled this job and what is on the other side that I cannot see, my last question is how do I get in to repair, amy advise would be very appreciated. Thanks Andy
Silly question but have you tried the car without the bonnet and nose cone off to see if the car still overheats, if it does then I think there could be something causing the problem but if it's fine then it could well be not getting enough air directed through the rad
Is your rad sitting upright so the air is hitting it straight on and did you have this problem before the engine was removed
I run a 2 litre pinto and had overheating problems a few years ago and the previous owner had removed the thermostat, I found out after trial and error that my radiator just wasn't getting enough air flow through it. I put a double core rad in which increased cooling capacity and then a electric fan but made sure that when the fan ran it pull air across the whole of the rad and the car now runs lovely with a thermostat back in even in traffic, to me if the thermostat is missing this has been an on going problem, also at the same time as my cooling problems i changed my volt meter for an oil temp gauge which I think is far more benifical, I noticed my oil temp was high especially when I was high revving the car, I do have a sump guard fitted but i did fit an air to air oil cooler in front of my rad, ran it from my oil filter with an thermostatic sandwich plate so not to cool the oil too much as this is worst than getting it too high, I had to change my oil filter for an cosworth filter, it passes the same oil rate and is ok with 20/50 oil but is smaller in length so it would fit inside my engine bay. The filter came from Burton and is a EFL298 FILTER this did bring my oil temp down and now it is happy days. Hope this helps Andy
Hi, I have a Sierra base S7 and this is about the only job I have been putting off for some time. The rear suspension, at the moment I am running is a Sierra set up with standard Sierra shock absorbers(new) with springs inboard on the rear subframe these springs are not standard but I have no idea what they are. I love the ride height of the set up at the moment and the wheels sit nicely filling the wheel arch but when riding along the rear is too soft and over pot holes and large bumps the suspension bottoms out . My question is what's the best way to sort this out with keeping the ride height the same and not going too hard, any advise will be gladly appreciate. Cheers Andy
Thankyou guys, for that information and as usual it is a great help to me. I have just sworn my motor and will be doing the rear first. Thankyou Pete for the offer of your spear springs and i may take you up on that when I come to the fronts but i will let you know if that is ok. Thankyou guys once again for your time and help cheers
Thankyou guys. It always amazes me the knowledge from the owners club and that is worth the membership fee in itself. Thankyou again, now I know what I will be looking and asking for. Cheers again Andy
Hi, my winter project is to change the rear and front suspension, i have the rear suspension covered but the front I need a bit of advice on. I have a sierra base S7 with in board spax adjustable coil overs that came in the kit I would think, I want to keep with the in board adjustable coil overs but i think the the springs are a little to hard but do not know what spring rate is fitted but more importantly what springs and shocks should I get and where to get them, i love the ride but just think a softer spring would be better without going to soft. Any advice would be grateful especially from anybody who has changed there shocks with this set up. Cheers Andy
Hi, in the end I took engine, gearbox and then prop out. Took the prop to Morris Bailey who made a updated prop in 24 hours and while I had the engine out i put a Kent cam fast road cam kit, a Kent Vernier pulley and lighten the fly wheel on my pinto. The car has been back on the road for 2 weeks and what a difference the upgrades had made it is almost like a different car the engine sounds different but it also spins up so much quicker and the cam doesn't slow the car down at low revs at all but when i put my foot down the car is so much quicker and more enjoyable. Thanks for all the advice and as always that advise has lead me to look in the right place, i think it is always nice to hear how our topics end. Once again thankyou guys
Thankyou guys for the advice even if it's not what I want to hear but thought that would be the answere. Two questions engine and gearbox out together or can I strip them out separately as last time I took the engine out there wasn't much room and i don't know weather both will come out together in one. As for the mot then yes I suppose he should of seen it. Thankyou guys for the advice as always it is much appreciated. Cheers Andy
Thankyou guys for the advise looked under car today and the prop uj has gone, which is nice to know that with your help I have traced the problem. Now to the downside is i cannot remove the prop as it is hitting the diff? I have a S7 and the floor is one sheet stainless and removing the tunnel is not an option. So has anyone done this job in the pass, is it drive shafts out and rear diff removed or can I cut the floor to allow a small access panel to assist with dropping the prop enough to pass the diff my only worry with last option sealing the structure any advise would be every helpful. Cheers Andy
Thanks nigel i was going to check that as well but at moment I have a big so crawling underneath the car is the last thing on my mind, when I am checking my prop uj I should notice a play with the prop in place just by turning it or does the prop has to come out and if so with the prop out could I run the engine and gearbox slowing to eliminate those too. Thanks for the advice and i will let you know what I find next week when feeling a bit better. As always the club's knowledge and advise is first class. Cheers Andy
No, the prop goes straight into the gearbox, if I get time i shall remove prop and check ug' s but thanks for the advice. Any advice welcome. Cheers Andy
No, but it can on instantly almost.i shall check the ju's but not feeling like I won't to at the moment may be at the weekend. Cheers
Sorry about spelling new tech with pro dick a text but I hope you get the jist
Hi, on the way back from a mot i noticed a vibration through the car. Now from the mot he didn't notice any wheel bearing etc that needed looking at and this can on all of a sudden, after 3000rom the car runs lovely when I freewheel no vibration and this vibration happens in any gear, i did check rear diff and gearbox levels all ok and as soon as I freewheel it stops with in a second or two, when im freewheeling the car is still in gear but no throttle. I do have a slight problem with number 3 and 4 pro carbonising which a oil on the plugs up which leads to a miss fire, clean plugs up and she's ready to go but this is totally difference to that and i know that I am going to address this when the car is off the road in winter. When car is stationary and i rev she seems ok. Any suggestions would be helpful the vibration which I think may be engine but not sure. This happens when engine and coil is cold as well as hot. I'm running a 2.1 pinto with standard can and standard carb 32/36 carb was new 3 years ago. Hope I haven't bored you all to deaf before you can help me. Cheers Andy
Hi Alan, me and Mrs should be there about 9.30 if all goes well. Cheers Andy
Hi Alan, I will be attending the Stamford car show this year, I have my invitation and car number already printed and would love to join and be in the robin hood display if that is ok and there is enough room, I should arrive about 10am and will make my way over to you which if it was like last year, just a turn to the left and park up, look forward to meeting you all again and sorry for not letting you know earlier as I have just found my invitation code in my e-mails, if you could just let me know if that is ok, Thanking you Andy
Hi all, I have fitted air blast oil cooler with a temp thermostat to my pinto engine and was wondering if the oil pump would be OK or should I upgrade to a high pressure and higher flow rate unit, I have a oil temp and oil pressure gauges fitted to the car. I have not run the car yet with the oil cooler but have always had good oil pressure. Just wondering if anybody can shed some light before I start her up as I do not want to cause any damage, PS I have primed the pipework and cooler with oil. Any information would be appreciated. Cheers Andy
