brumster
Posts posted by brumster
  1. Hmmm. No-one's dicked around with the map, I take it?
    If it started immediately after you changed those bits, then "ergo" it has to be in some way related to them (or incredibly unlucky that another problem started at exactly the same time!)...? So... doesn't make much sense really, maybe ignore the HT/coil/plug aspect and just treat it as a separate problem. In which case I'd be looking at the cold start map and fueling first. If you had an air leak the idle would most likely be off...
  2. No, I know what you mean. I sometimes have to cook for the inlaws at their house, which is halogen hobs. I utterly hate it. There seems to be no control between the lowest and highest settings; your main control of heat is just the size of the hob and that's it.
    Our new induction hobs are totally as controllable as gas, and just as instantly (in fact, they warm up way quicker, for the technical reasons above).
    About the only downside I have with them is the fragility; you can't clatter pans around on the jobs or shuffle them on the surface as you'll damage it, exactly as fozzy says above.
  3. An obvious suggestion, can you put the old stuff back in one by one to see if the problem goes away :) ?
    I'm also not a fan of these "fancy" mutli-prong spark plugs. It would seem to me you're maybe not getting as strong a spark at the plug - which could be any of the aspects you've changed, so it sort of makes sense.
  4. That's interesting. Makes sense; I've seen (on competition cars) that braided lines can fray over time but naturally put that down to rather extreme use :D. They also don't respond well to kinking or crushing and stay deformed afterwards, so I guess that's probably the problem.
  5. Braided hoses are typically PTFE lined, not rubber. They are prefferential in every way, I'd say - they are more resilient to hits/cuts/damage, they last longer and they also maintain line pressure better than rubber. That's not to say there's anything wrong with rubber hoses, like you say they suit manufacturers of production cars day in and day out! As with all these things it's down to cost, I suspect :)
    You can also get braided lines made up to pretty much any length you want of course, but rubber ones you'll be having to half'inch them from a production car where the dimensions and fittings are exactly what you need.
  6. I think that is more aimed at some of the earlier, narrower Sierra models where the subframe protruded outside of the body; in these cases they were often covered with a small dome (not sure whether it was stainless or GRP). It all depends if the part you're looking at there is below the "floor line", and that's defined in Annex 1 of the exterior projections - basically if you imagine a 30 degree cone on the floor, sitting flat on the floor and then pushed up to the car, where is touches the car at the front, back, sides, etc. defines the floor. At a very simple level, if you can put a flat ruler onto the edge of the stainless panel in that photo, and put it at an angle of 30 degree down under the car.... then if it touches the subframe, it needs to be rounded edges and so forth (all the usual exterior projections rules). Or cover it (but obviously whatever you cover it with also has to meet those rules).
    If however it's below that floor line (ie. the cone doesn't hit it) then it's not something to worry about but - looking at is - I don't suspect that's the case (ie. you have to consider it) :(
  7. 8 hours ago, phaeton said:
    Handbrake is perfect, not sure what the K3's used as they were Metro front subframes on the rear,
    GTM provided a load of cut steel that you sandwiched together to make up a secondary caliper, and you then popped a couple of Citroen 2CV brake pads (about the size of a 2 pence piece!) into each side and presto, a handbrake mechanism.
    It was borderline effective 😕
    (I'm being polite)
  8. 3 hours ago, Vaughan said:
    Thanks Brumster, you da man!
    is the nut on the end of the braided hose ok for Iva?
     Thanks
    Vaughan
    Not quite sure what you mean, but if you're on about sharp edges and whether they'd fail it for that, you will be fine. They're not that pedantic, that I'm aware of ;)
    • Thanks 1
  9. Turn the wheel to full lock both ways, and with the suspension on full bump and full droop - if the hose doesn't get kinked, touch anything or get pulled taught at any point, then it'll be fine ;)
  10. Little cherry on the cake; treated the car to some new seats - the ubiquitous Odyssey seats from Intatrim....
    n_xtyMHNlgULFjbJQfNMDWjGV8bXNIkt_WS2R6_c
    Ordered at Stoneleigh, ready 6 weeks later, look nice - just set the car off a bit better than the previous onces I had from the Exmo that were blue (to match the Exmo)....
    • Like 2
  11. Good news - I had the Mountney wheel and Westfield's (old) solution uses the same - a Mountney wheel with a rubber pad over the centre. I was at Stoneleigh and they had the pad for sale, snapped it up, fitted over my Mountney wheel centre, passed IVA.
    So I can recommend that route for you - just get the pad, pop it on your existing wheel, job's a good'un ;)
  12. Even on my kit, IVAd and on the road last year, it is the same - it is the special notes that state the emissions requirements. So I don't think you have any issues with VOSA, your V5 is consistent and correct. The problem you have is your MOT tester is an arsehole who can't read the rules for testing. My advice - find somewhere else if he keeps pushing the issue.
  13. I hadn't really thought about it - these harness would probably be no good for an S7 anyway, to be honest, they'd be too short in the should straps. I did have a thought about replacing them for ones with better adjustment buckles so, yeah, they could be for the right price. Probably best if you're interested in the seats, you take a look at the harnesses at the same time and if you think they'd suit your S7 then no worries, we can sort something out.
  14. They tend to be absolutely fine with you entering/leaving via the paddock gate, just avoid the start area and the run up to the curve - as you say, speeds, but also they like to keep the start straight in good surface condition for the competitors (ie. keep it free of oil spills/etc)...
    So enter onto track via paddock gate and immediate right.
