Hammy360
Harnesses
I have Luke harnesses fitted and have added a photo as I want to know if the trim is sufficient for IVA. If not can anyone tell me what needs to be done
Share this post
Link to post
You're unlikely to get a definitive answer on this as it will depend on the tester but it might fail on the sharp edges on the catch that releases the belt from the eye bolt - my belts didn't have the catch and were retained with a hex bolt (with nut cover) through the belt and they still failed on the 'sharp edges' around the metal of the belt.
I made 4 small ally covers, covered with foam and vinyl to cover the entire end of the belt.
For IVA I'd be more concerned about the belts passing through the holes in the seat back. Under load, the belts look like they will pull tight against the outside of the belt slots - you may need to demonstrate that the seat is strong enough to support this load. Alternatively, see if routing the belt around the headrest part of the seat still allows them to pass over your shoulders when worm. The belts are most effective when then are routed in a straight line before they are under load, kinks in the belt will pull straight under load meaning you move forward.
Share this post
Link to post
Interesting as theyre GBS seats and GBS harness mounting points. Cheers
Share this post
Link to post
I know, which is why you'd expect them to be in line with one another. Plenty of cars have probably have passed with these seats and harness positions so don't give up hope but if they're tested to the letter of the IVA manual they'd almost certainly fail. The problem (or not, depending on how you look at it) is that different examiners will have different interpretations of the regulations.
On my IVA (at Derby) the tester was also training another examiner so I knew I was in for a rough ride and is why I failed on my upper harness mounts and also even sharp edges on my spare wheel (that's on the tread of the tyre - not the actual wheel!).
My personal view is that GBS shouldn't provide a chassis with seatbelt mounts that aren't positioned correctly for their own seats and should either leave the mounts off and let the builder fit them, fit the mounts when the builder has told them what seats are being fitted or provide a number of mounting positions to allow some adjustment.
Share this post
Link to post
For IVA you can run the belts round the seat that way the seat is not assessed for strength.
If it were me and as you have easily removable belts, run it as it is now, if the examiner is not happy, remove and wrap round ask him to asses again, if it fails at this point, take it home and reweld the mounts
Share this post
Link to post
mine went through with the belts through the seats, I have heard of people failing with belts round the seats as the belts pull on the seat itself
as snapper says, its a bit hit and miss and is down to the examiner and what sort of day he is having
Share this post
Link to post
never heard of a zero failing with the standard seats and mounts.
the mounts are positioned to give owners the option of using different seats, the seats supplied by GBS are designed to take the load.
putting the straps around the headrest will mean they are not positioned on the occupant correctly (fail)
must agree, the clips on the belts may cause a problem.
easy enough to make a cover out of a strip of rubber, like the strip that comes with the windscreen kit.
GBS will tell you how.
Regards
Share this post
Link to post
Can you lock wire the spring loaded clip John, Sometime clip on belts fail because they could come off (yeah right)
Share this post
Link to post
Yeah Dave I remember we spoke about that before and the gear is in my IVA roadtrip bag (which seems to be getting bigger lol)
Also Dave whats your opinion on the seats / belt routing mentioned above mate?
Edited by Hammy
Share this post
Link to post
Leave them like they are, the only poor point with harnesses in the zero is the lap strap fixing point,, You need to be able to adjust the lap belt length whilst sat in the car, depending on the harness used the adjuster can tight between the seat and the tunnel,
Check it can easiyl be adjusted whilst sat in the seat, if its tight then spray some silicone spray on the strap 4 inches either side of the adjuster and work it back and forth..
When the car passes make sure to clean the belts with some carb cleaner to remove the silicone, (you wouldnt want the lap belt part slipping loose when your upside down sliding down the road)
Share this post
Link to post
cheers Dave, checked the adjustment a couple of weeks ago and all working well mate
Share this post
Link to post
"the seats sold by GBS are designed to take the load"?????
How do you know that, is there technical documentation to prove that?
If so you would need to produce that at IVA if the examiner requested proof
Share this post
Link to post
trust me, you don't, and they pass as they are.
the only known issue, except for sharp edges
Share this post
Link to post
I had the same comment about the lap strap adjuster being difficult to reach from the examiner.
(GBS harness and seats) He thought that they were narrow seats until I said the car was the wide version and that the mounting points for the lap part had been moved forward to accomodate the adjuster.
He was happy with the harness going through the loops in the seat back and as my top mounts were below the boot surface I had put on, edges weren't a problem.
Simon.
Share this post
Link to post
  • Similar Content
    • By kgnoble
      Well it failed!
      Full story is in the blog, but the majority of stuff was very minor, a loose screw here, a missing grommet there.  Most important was that he spotted a very small leak in the master cylinder - I will replace that very shortly.  There was also an issue with the (MotaLita type) steering wheel which has too many holes and too much wood.  Otherwise, side repeaters apparently necessary, and the rear foglamp/reversing light combo needing a shim to make it present the light horizontally on a sloping surface.
      What was obvious was that a neatly presented car immediately gets the examiner on your side.  I suspect he erred on the generous when assessing seat heights, headrests, two speed wiper speeds, headlamps and quite a lot else.  He was very happy to chat and was pleased to see that I obviously had worked through the IVA manual.
      So - another month to fix the items, a retest and I should be away.
      Thank to you all for your comments and support - it has been incredibly helpful and generous.
      Keith
      www.cageyenne.co.uk/wp
    • By GCash
      Hello, I thought I would let everyone know how I have got on with putting my Robin Hood through the IVA and to ask a few questions...
      My Robin Hood 2B was given to me by my kind friend part finished, I believe it was originally bought in 2002.  It is based around a 1989 Sierra with a 2.0l Pinto with a 30/34 DFTH Weber carb.  I have stripped it down and finished it over the last eighteen months and I am quite pleased with the result (or at least I was).
      Attempt one happened at the beginning of May and didn't go well at all.  Prior to the test I had a garage down the road check it out and everything seemed ok apart from a bouncing fuel gauge.  I didn't get the car back in time to sort the fuel gauge, so I just had to go for it.  On the day of the test I filled it up at the petrol station in preparation for the fifty-mile journey from Blackpool to Chatterton.  Fuel ended up leaking everywhere from the fuel sender and the car started running rough.  Before I got too far from home, I just took it round the block where I broke down a few times as well as got pulled over by the police.  I had all the relevant paper work so being pulled over wasn't an issue and I managed to limp the car home.  Unfortunately, I couldn't make it to the test so £450 down the drain.
      Before my next attempt I serviced the carb, replaced the fuel lines, filter and fuel sender, fitted new spark plugs, leads and coil (from Accuspark) as well as checking the ignition timing and mixture. The timing was out, and I set it to about six degrees with the vacuum lines blocked as per the manual.  There was also a leak on the line from the manifold to the servo which I fixed.
      Yesterday I set off nice and early for attempt two.  Everything went well for the first twenty-five miles until I could feel the car needing more and more power to maintain speed.  I pulled over and found that the brakes had come on and while I at the side of the road they came on completely.  After looking around it I suspected that the servo was at fault either too hot, getting to much vacuum or faulty.  I managed to get to the test centre (with frequent stops to keep checking) and on the way there the car started to run quite rough. It struggled to pull away and didn't like running at slow speed although it idles fine. Despite being late they completed the test and found the following...
      Metered Emissions - the HC reading was 4260 when the max is 1200.  The car struggled to run at the required 2,000 rpm it just kept hunting between 1,000 and 3,000.  The reading from the garage prior to attempt one was fine, well below the limit.  I suspect I have messed up the mixture after the carb rebuild. Brake pipe or hose must not be exposed to excessive heat.  The car has the original sierra manifold and the exhaust has a heat wrap around it.  The servo is close to the engine and heat shield I made is obviously not up to the job (see picture, although the heat shield has been removed).  I am thinking about removing the servo all together as described in other posts and then make a bigger heat shield. Brake warning light - The light on the dash functions with both the handbrake and the low brake fluid level switch.  However, the low fluid switch doesn't seem to work.  Am I correct in thinking that if I fix the low brake fluid switch and can prove it works by unscrewing the top that will pass?  I can test the light from the driver’s seat using the handbrake or do I need a separate switch? A couple of sharp edges right under the dash that I missed.  I have already put edging on them. The hand brake isn't working on the near side wheel.  I will have to investigate. Brake lights are on all the time.  I knocked the brake switch off while checking my brakes when stuck at the side of the road and have now fixed. Side repeaters are mounted on the body of the car and do not give the five degrees of visibility from the rear.  I need to move them to the cycle wings. Headlight aim was out, I must have knocked them as they had been aligned by the garage. Fog lights come on with the side lights.  I going to change the switch feed using diodes as described by other posts. Pinch nut on the from suspension was loose.  The pinch bolt was tight, and I had put a safety bolt through to dummy strut but completely missed this.  Stupid boy! Maybe unsurprisingly because of the brake issue they wouldn't let me drive it home and I had to shell out to be recovered to Blackpool 😢.  Yesterday was a very frustrating day to say the least! I have already fixed some of the issues and apart from the engine and the brakes my car is fine, ha!
      When I got home, I checked the spark plugs and they are black, so I guess it is running rich?  I have a colourtune kit but I was struggling to use it, I will have to have another go.
      My dilemma now is how best to take it for the retest, do I risk driving it again?  And, how am I best getting the engine tested/tuned without having the ability to drive it?  Maybe I need to find someone with a trailer for the retest and a rolling road session?
      Graeme
    • By GCash
      Hello
      I am coming to the end of the build of my Robin Hood 2B and I am just in the process of fitting the windscreen. I have read numerous threads and the IVA manual and just want to confirm a couple of things.
      These are the markings on my windscreen...
      Am I correct in thinking that this won't get through the IVA because of the missing Roman numerals above the E?
      If I remove the windscreen, wipers, heater and washers and get it through the IVA would it be a bad idea to fit it anyway because it would be too dangerous?
      Graeme
    • By will.holroyd
      I'm in a position where I would like to get offical proof of the year of manufacture of my mazda engine. I understand that for emissions test during IVA if you can demonstrate the true age of the engine the test parameters can be adjusted accordingly. Please correct me if this is not true.
      Unfortunately I naively bought my engine a few years ago without any documents from the original vehicle just assuming I would be issued Q plates and I didn't even consider the different test parameters. I recently contacted the homologations department at mazda to see if they were able to provide a formal confirmation from the engine number, but I was told that they can only do this using the VIN number. So now I'm at a deadend.
      Has anyone been able to overcome a similar issue? If so how.
      Or, does anyone know how I go about finding the original VIN from the engine number so I can then go back to mazda?
      The only info I have is the engine number.
      Thank you
    • By Turboz
      Hi guys I'm on the rolling road tomorrow and can't wait...
      I was always going to make the car track only but I'm wondering now if it's worth putting on the road for a better re-sale in the future or would I not be worth the potential gain in the future ? I already have a Sunday car so I'm not to bothered about driving it on the road.
