June 19, 20197 yr Hello, I thought I would let everyone know how I have got on with putting my Robin Hood through the IVA and to ask a few questions... My Robin Hood 2B was given to me by my kind friend part finished, I believe it was originally bought in 2002. It is based around a 1989 Sierra with a 2.0l Pinto with a 30/34 DFTH Weber carb. I have stripped it down and finished it over the last eighteen months and I am quite pleased with the result (or at least I was). Attempt one happened at the beginning of May and didn't go well at all. Prior to the test I had a garage down the road check it out and everything seemed ok apart from a bouncing fuel gauge. I didn't get the car back in time to sort the fuel gauge, so I just had to go for it. On the day of the test I filled it up at the petrol station in preparation for the fifty-mile journey from Blackpool to Chatterton. Fuel ended up leaking everywhere from the fuel sender and the car started running rough. Before I got too far from home, I just took it round the block where I broke down a few times as well as got pulled over by the police. I had all the relevant paper work so being pulled over wasn't an issue and I managed to limp the car home. Unfortunately, I couldn't make it to the test so £450 down the drain. Before my next attempt I serviced the carb, replaced the fuel lines, filter and fuel sender, fitted new spark plugs, leads and coil (from Accuspark) as well as checking the ignition timing and mixture. The timing was out, and I set it to about six degrees with the vacuum lines blocked as per the manual. There was also a leak on the line from the manifold to the servo which I fixed. Yesterday I set off nice and early for attempt two. Everything went well for the first twenty-five miles until I could feel the car needing more and more power to maintain speed. I pulled over and found that the brakes had come on and while I at the side of the road they came on completely. After looking around it I suspected that the servo was at fault either too hot, getting to much vacuum or faulty. I managed to get to the test centre (with frequent stops to keep checking) and on the way there the car started to run quite rough. It struggled to pull away and didn't like running at slow speed although it idles fine. Despite being late they completed the test and found the following... Metered Emissions - the HC reading was 4260 when the max is 1200. The car struggled to run at the required 2,000 rpm it just kept hunting between 1,000 and 3,000. The reading from the garage prior to attempt one was fine, well below the limit. I suspect I have messed up the mixture after the carb rebuild. Brake pipe or hose must not be exposed to excessive heat. The car has the original sierra manifold and the exhaust has a heat wrap around it. The servo is close to the engine and heat shield I made is obviously not up to the job (see picture, although the heat shield has been removed). I am thinking about removing the servo all together as described in other posts and then make a bigger heat shield. Brake warning light - The light on the dash functions with both the handbrake and the low brake fluid level switch. However, the low fluid switch doesn't seem to work. Am I correct in thinking that if I fix the low brake fluid switch and can prove it works by unscrewing the top that will pass? I can test the light from the driver’s seat using the handbrake or do I need a separate switch? A couple of sharp edges right under the dash that I missed. I have already put edging on them. The hand brake isn't working on the near side wheel. I will have to investigate. Brake lights are on all the time. I knocked the brake switch off while checking my brakes when stuck at the side of the road and have now fixed. Side repeaters are mounted on the body of the car and do not give the five degrees of visibility from the rear. I need to move them to the cycle wings. Headlight aim was out, I must have knocked them as they had been aligned by the garage. Fog lights come on with the side lights. I going to change the switch feed using diodes as described by other posts. Pinch nut on the from suspension was loose. The pinch bolt was tight, and I had put a safety bolt through to dummy strut but completely missed this. Stupid boy! Maybe unsurprisingly because of the brake issue they wouldn't let me drive it home and I had to shell out to be recovered to Blackpool 😢. Yesterday was a very frustrating day to say the least! I have already fixed some of the issues and apart from the engine and the brakes my car is fine, ha! When I got home, I checked the spark plugs and they are black, so I guess it is running rich? I have a colourtune kit but I was struggling to use it, I will have to have another go. My dilemma now is how best to take it for the retest, do I risk driving it again? And, how am I best getting the engine tested/tuned without having the ability to drive it? Maybe I need to find someone with a trailer for the retest and a rolling road session? Graeme Edited June 19, 20197 yr by GCash Mentioned heat shield was missing from picture
June 19, 20197 yr You've not had much luck have you? Will be worth it when it is on the road! Have put some responses to some of your issues in red below Metered Emissions - the HC reading was 4260 when the max is 1200. The car struggled to run at the required 2,000 rpm it just kept hunting between 1,000 and 3,000. The reading from the garage prior to attempt one was fine, well below the limit. I suspect I have messed up the mixture after the carb rebuild. I would suggest getting the engine setup properly on a rolling road, there is a multitude of things that could need addressing here and this would be best way to find and fix them all. Brake pipe or hose must not be exposed to excessive heat. The car has the original sierra manifold and the exhaust has a heat wrap around it. The servo is close to the engine and heat shield I made is obviously not up to the job (see picture, although the heat shield has been removed). I am thinking about removing the servo all together as described in other posts and then make a bigger heat shield. I removed the servo on mine and did not have a heatshield fitted and not had any issues. Brake warning light - The light on the dash functions with both the handbrake and the low brake fluid level switch. However, the low fluid switch doesn't seem to work. Am I correct in thinking that if I fix the low brake fluid switch and can prove it works by unscrewing the top that will pass? I can test the light from the driver’s seat using the handbrake or do I need a separate switch? Handbrake is fine to test the light, and yes if you remove the cap and the light comes on, that confirms it is working correctly. Headlight aim was out, I must have knocked them as they had been aligned by the garage. They will go out of alignment very easily just driving it a few miles on the road, most IVA inspectors will allow you to align using their equipment on the day
June 19, 20197 yr Def do the trailer option fortunately I have access to one so used it for my Iva just piece of mind that you will at least get there! A rolling road road session is well worth the money whilst on mine it wasn’t running quite right and I too had the accuspark plugs in. They whipped them out and fitted some good old ngk plugs and that made a huge difference to the running. Maybe worth a try.
June 19, 20197 yr Brakes coming on on their own as it were, is a sign that the master cylinder is not returning to its fully open position. This is sometimes due to a too long push rod or the brake pedal return restricted. This prevents the fluid being able to flow back into the master cylinder. It sounds like there is a problem with the carb could be as simple as the float not shutting off the fuel supply. Hunting indicates an air leak in the inlet system, check all the gaskets and any hoses that are connected to the manifold.
September 9, 20197 yr Author Well I finally passed the IVA and my documents have been sent to the DVLA! To summarise what I did in case anyone is interested... - I did away with the servo and just ran the standard Sierra master cylinder and brake pads. I beefed up heat shield to be safe. - After some inspection the valve stem seals had fallen to pieces and I replaced them with the head in place using the popular rope technique. - I replaced the handbrake cable and put another adjuster on so I could balance both sides. - I just aligned the headlights on the garage door using masking tape As for getting the car there and back I employed the service of a local transport company called RS Motor Co. Now just to wait patiently for my log book!
September 9, 20197 yr Well done Graeme, you must be pleased. Hopefully you won't have to wait too long for your documents and can get a few miles in before the winter. If you can live with the higher pedal effort, removing the servo is a good move as it does give more feel to the brakes. I've just swapped to my third master cylinder trying to get a good balance between pedal effort and braking performance and I think I've finally got it how I want it.
September 9, 20197 yr Excellent news, a great achievement. Why don't you come to the End of Season Bash (EOSB) you can come in a tin top and meet fellow members, camping is available. Look forward to seeing your car on the road.
