Guest Powerme
I'm part way through the build of a Zero and I'm stuck for a prop shaft. So far GBS have been unable to supply one to me.
MT75 box, sierra diff with 2.0l blacktop. Westfield can supply a prop with the following dimensions : The shortest length is 760mm
The longest length with the slider fully extended is 810 slider is in the middle. Can anyone tell me if this is a suitable prop?
Guest merc190provan
Surely this is a stock item for GBS ??
Marty Smith
I'm not sure about the spline fitment on the '75 but I had 105speed make me up my shaft, completely custom to my spec. You could try them - they can only say no, I guess :). £130 notes all in and cracking service - turned it around in no time, and not much more than it was going to cost me to have my existing shaft lengthened.
Guest Powerme
Marty Smith
It's 'awaiting new stock' and has been for several weeks :(
Mike at Autoprop will make you one. Just tell him Sierra diff and MT75 without the doughnut. He made me the adapter plate to fit the gearbox. The whole unit is 23 inches long, slider included.
Autoprop
Spinney Lodge, London Road
Felbridge, East Grinstead
Sussex, RH19 2RA
Telephone: 01342 322623
Fax: 01342 314947
Email: sales@autoprop-uk.co.uk
Guest Powerme
have you actually called gbs?
called and visited several times...... went today and was told 'next week' for the umpteenth time :(
Guest Powerme
Autoprop
Sussex, RH19 2RA
Fax: 01342 314947
Thanks for that Graham, I'll give him a call next week
  • 2 months later...
Guest zerorace
how did you get on with your prop?
did you get it sorted if so how much it you don't mind me asking.
graham
