Tank is 865mm across, 210mm deep, 200mm tall (255mm if you include the sub-tank on the underside that achieves the "surge protection").
Apologies for the state of the filler neck, my welding skills back in the 90's weren't what they are now (they're not brilliant now, but they're certainly better!). I flushed it out just now and noticed a couple of pinprick holes, so I'll sort those out in the week. Very, very small - never even noticed them when it was in the car, but I'll patch them up while it's out.
Also now for sale and added to original post - sierra steering rack with quick rack/pinion fitted. 2.8 turns lock to lock, with 6" of arm travel between extremeties.
£50
Guest Sames69
This week I'll be stripping down the Exmo for donor parts for my Zero build. Most of the bits, as you can imagine, I'm keeping but I figure some bits may be of interest to others. Prices are ONO, and all plus shipping.
Front swept-style arches (Oxford Blue) £20/pair
Rear two-piece wide arches (Oxford Blue) with stainless protector panels £20/pair
Nosecone + grille (Oxford Blue) £15
Bonnet, stainless, w/louvres, dinted in top - useful for steel/louvres maybe? £10
Rollover bar, original £30
Windscreen, frame and black side supports £40
Front tie bar kit £20
Light set (headlamps, front indicators, rear clusters, reverse, fog) £20
Rear sierra subframe, arms, springs (note nothing else - no hubs, shafts, etc) £10
Stainless steel tub - for scrap, spare steel, etc. *NO VIN, NO V5* £100
ETB mechanical speedo, 80mm, white on black, geared for Type 9, with cable £40
ETB rev counter, 80mm, white on black, coil pack driven, can include homemade converter to run off ECU £40
Oil pressure gauge, with sender, white on black 52mm £15
Water temperature gauge, with sender, white on black 52mm £15
Fuel level gauge, white on black 52mm no sender, unknown calibration but does not work straight with Ford sender £15
Exmo fuel tank - includes brazed compartment for fuel injection (no need for swirl pot) £40
Front dampers £10/pair
Sierra quick rack (2.8 turns) inc arms £50
Items located in Brum obviously :)
edit : Pics slowly being added to :- https://picasaweb.go...feat=directlink
Guest Sames69
Hi, my name is james. do you still have the windscreen? If so could you please let me know on 07854057827.
Thank you
