This week I'll be stripping down the Exmo for donor parts for my Zero build. Most of the bits, as you can imagine, I'm keeping but I figure some bits may be of interest to others. Prices are ONO, and all plus shipping.
Front swept-style arches (Oxford Blue) £20/pair
Rear two-piece wide arches (Oxford Blue) with stainless protector panels £20/pair
Nosecone + grille (Oxford Blue) £15
Bonnet, stainless, w/louvres, dinted in top - useful for steel/louvres maybe? £10
Rollover bar, original £30
Windscreen, frame and black side supports £40
Front tie bar kit £20
Light set (headlamps, front indicators, rear clusters, reverse, fog) £20
Rear sierra subframe, arms, springs (note nothing else - no hubs, shafts, etc) £10
Stainless steel tub - for scrap, spare steel, etc. *NO VIN, NO V5* £100
ETB mechanical speedo, 80mm, white on black, geared for Type 9, with cable £40
ETB rev counter, 80mm, white on black, coil pack driven, can include homemade converter to run off ECU £40
Oil pressure gauge, with sender, white on black 52mm £15
Water temperature gauge, with sender, white on black 52mm £15
Fuel level gauge, white on black 52mm no sender, unknown calibration but does not work straight with Ford sender £15
Exmo fuel tank - includes brazed compartment for fuel injection (no need for swirl pot) £40
Front dampers £10/pair
Sierra quick rack (2.8 turns) inc arms £50
Items located in Brum obviously :)
edit : Pics slowly being added to :- https://picasaweb.go...feat=directlink
Guest kwakatim
Hi I would also be interested in the rear arches and the nose cone and maybe the wind screen if you still have them thanks Tim
can I have a bit more detail on the front tie bar kit please, size/material etc is everything needed included ie internal bracing. are there any pics of it installed.
P.M . your postal address and I 'll forward all details plus photos mower man :clapping:
Tie bar kit was commissioned by Dave Andrews back in the day; the outer brackets fabricated by a prototyping shop where my old man worked and the inner just some pieces of angle. I'm sorting out photos right now and will get them uploaded to Picasa...
https://picasaweb.google.com/112513769957404714981/ExmoBreaking?authuser=0&authkey=Gv1sRgCKaE883R7ZT2Cg&feat=directlink
In the past year or 3/4 I have seent out a no of instruction/guides to this after doing my own car following Dave Andrews guide lines and have had numerous messages of thanks from those involved , if any one is interested p.m/ me mower man
Thanks for the offer mowerman, but I think I already have the design sheets. Was just after an easy pre-made buy.
Thanks for uploading pics Dan but I think I'll wait to make my own with a bend to avoid the wheels on full lock. I need full lock to get in and out of work carpark so can't use bump stops in the rack.
No worries. It is a mod certainly worth doing for Exmo owners, I'll admit (we had to do it out of necessity of clearing the K-Series sump, but in reality it was worth doing even if the sump wasn't an issue).
Nosecone and rear arches sold & gone.
Thanks for the bits Dan - was good to meet you tonight.
Just to confirm for anybody else that is interested - Exmo nosecone is identical to 2B conecone (pictures of it offered into position on my 2B)
Tony
