Guest Darren2010
Hi Guys. I'm just about to start plumbing the new Radiator in and was wondering if any one has any advise on the best, most economical place to source a few right angle bends from.
Darren
Guest Darren2010
Thanks Blue. I was thinking more of new ones, maybe silicone, for a bit of piece of mind!
Don't wast your money on second hand hoses, work out what you need then go on eBay and order silicone as they are much easier to work with than rubber. They slip on easier and seal much better when you tighten they up as they are more supple. I used auto silicone hoses, they have loads of listings for all sizes, angles and colours. Doesn't work out that expensive either as you only do it once avoiding lost coolant and hassle. I reckon I did my complete set on my red top for less than fifty pounds
As above either Auto Silicone Hoses or Derbyshire Performance Hoses on ebay are pretty good.Looking at your pictures you may be able to use some of the lengths of bendable silicone hose and cut your number of joints down
Guest alfaGTA
Yes auto silicone hoses (ASH) on eBay, cheaper than on their site!! Also b&q sell an aluminium TV aeriel pole-it's 32mm od and ideal for a straight run and cheap!
Don't forget good quality hose clips will prevent leakage and slippage!
And since you are fairly local if you bring your ally sections to me once they have been cut to length I can put the bead on the end of them to make sure they won't slip off.
Iain
As above, but look for ash clearance store on eBay.
Have you got a link to this store ? I can't find it.
Guest peter2b2002
that's were I got some for my z3 very quick and cheap
peter2b
