Wanting a small compressor to run air gun etc for engine pulleys etc
240v plug in type if anyone got one cheapish
Edited by jaimo
You will not get a 12v compressor with enough umpf to use air tools.
If you do manage it, please let me know.
Being at home and not having a compressor to drive any of my many air tools is a bummer.
However I have bought a cheap 24v li ion battery powered impact driver that easily sees off wheel nuts and such.
If you spend a fortune on snap on, you will be able to do almost anything with it that you can do with any 1/2 inch air driver.
I can get mega discounts at a company called parker beumanor in Leicester look them up on line I get up to 70% off depending on product. If anything takes your fancy I could get you a price and pick it up
Guest peter2b2002
lidle have them in at my local and stick welders
peter2b
Now if I was a little younger, or had some room in my shed or garage, I would buy one of those.
Not even £1 per day if it only lasts a year.
Not a fault as such but expect the 13 amp plug fuse to blow occasionally -- the motor start-up current will be right on the limit & the fuse will fail because it gets "tired" of repeatedly running at max amps.
Dan going to get garage built then I will get you to get me a few toys
  • 5 weeks later...
Guest h34ds
Jaimo - what about the Clarke electric impact gun - less than £50 and should do the job.
I bought an Aldi special ! 50L tank v- twin motor , 3hp. I must say its Superb. Bought it n the clearance £120 with three year warranty
