Gusty
Content Count
251 -
3
Gusty last won the day on August 25 2016
Gusty had the most liked content!
37 ExcellentAbout Gusty
Rank
Wheely good builder!
- Birthday 12/12/1978
Car type
2B
Full name
Andy
Gender
Location
Hinckley, Leicestershire
How much is the calendar
Hi, Size of engine , petrol/derv? Cheers
Mine was a pig to start until I put a new Bosch 1.4KW starter motor on along with a new battery. Starts great now .
Nice to hear you got it sorted
Hi, I had issues similar to yours after my car had been standing for 7 years. It was due to fuel, sender seized up, tank full of crap, fuel line degraded . Cleaned tank out , new sender, new fuel line and filter. Problem solved. Good luck
Clayfield& hall Hinckley. Excellent old school work shop
Thanks for the replies. I think one of the center bolts has bottomed out. I will remove bolt shorten by 10mm and try again! Cheers Ps I will report back when I find the time to do it!
All good advice. Thank you
Everything was spotless. May try some rad weld!
Nipped up all bolts and still weeps????
Hi all, Coolant leak exhaust side from where the head joins the block. It's only a very slight weep, engine runs and drives sweet as a nut. 100 miles max since full rebuild. Head skimmed, block straight, Victor Reinz Gasket, stretch bolts tightened to the correct spec and procedure. Any ideas please ??? Can I try nipping the head bolts up a little more? If so, to how many Newtons? The last stage with stretch bolts is to turn through 90 degrees which I did. The old type of bolts was to torque to 115nm would this be ok? Any help much appreciated. Thanks Andy
Congratulations both. I agree with Steve49er , we dropped our daughter off at Sheffield Uni yesterday . I don't know where the time has gone . Make the most of every minute and enjoy. Happy times ahead. Rgds Andy
Disregard . Just been out to check constant 12.6v then looked at back of alternator and realised it wasn't plugged in!!! What a numpty!! Cheers
