May 14, 20179 yr Can someone tell me what front stub axles are fitted to a 2b+ as mine is running solid discs and are warped so need vented anyway
May 14, 20179 yr Most 2bs will have Sierra discs If it has solid changing to vented will need discs and calipers
May 15, 20179 yr before you go to the hassle and expense of changing, check the runout on the discs. Most brake judder is due to excessive runout
