Theducks severely over running Winter Mods - Youtube Series
Saturday didn’t quite go how I had hoped...
  • Replies 121
  • Views 28.2k
Most Popular Posts
Posted Images
  • 2 months later...
Slowest desoldering effort EVER :D
I did have to speed that section up just a little bit... 😂
  • 3 weeks later...
I really want 4 pots...
It’s a simple enough solution. 🤣
I had the same problem with the turbo security (trying serrated nuts etc. to solve the loosening problem) which was made worse by only limited access under the T3 turbo.
Final solution was to get the faces of the exhaust/turbo seating machined so that no gasket was required(original specification) and using "nord lock washers" to hold everything in position.
This has finally seemed to have done the trick, the only drawback is that the Nord system stretches the thread when undoing and therefore needs the studs to be replaced when remove, but better than turbo breaking loose.
Tried and tested way to stop turbo bolts self loosening is piss in a biscuit tin and soak the nuts for a few days then fit them wet. Sounds mad (and questionable) but works. I decided to use castle pins on the head to hold the manifold and v band mounts for turbo for rapid changes, but piss does work. 😱
In my case it wasn’t the nut coming loose, but the stud backing out of the head. Long term i will likely need to make a repair to the head, but for now I am hopeful this will work.
  • 3 weeks later...
Thanks, wanderer. I am definitely going to try and keep to the KISS philosophy on this one and intend to be back on the road in time for stoneleigh!
Last picture I took before the chassis was taken away, was a bitter sweet moment.
I have one final video to come, a kind of celebration of the kit, which will be out Christmas Eve. For now though, here is a teaser for the next project.
If people want me to, I will start a new thread and continue posting the videos on here.
It’d be a shame to end this thread, besides I’m interested to see what you’ve got planned.
Anglia perhaps ?
