Sign in to follow this
keith kelly
Sierra Drum Brakes
Hi all I have 1.6 drum brakes on the rear of my zero which are 203mm drums. Cant seem to get them anywhere however there are plenty of other ford drums that are 203mm does anyone know if any of these fit.
Looking at old escort/orion capri etc the all have same bolt pattern. I have found some things online which suggest they will but nothing concreate.
regards
keith
Share this post
Link to post
One way may be to check if these cars all use the same part number for brake shoes,
otherwise invest a tenner in a breakers yard & see?
Share this post
Link to post
Whats up with your drums? I have a pair of 1.6 drums and all the links but they have been sat around a while and need cleaning up and maybe a skim. As far as I know they have little wear just surface rust.
Share this post
Link to post
they are binding, shoes on that side are unevenly worn so think they may be distorted. Don't seem to be a lot of breakers in Leicester these days
Share this post
Link to post
Get the drums off Jez and speak to Kerry nicely and see if he can skim them.
Share this post
Link to post
Got new shoes arrive today so will swap them out and see if that solves it alternatively have found a source for new drums at sensible prices.
Share this post
Link to post
I can give them a skim if needed
Share this post
Link to post
try using eurocarparts or GSF to cross reference part numbers between different models of cars
Share this post
Link to post
Euro seem to be out of most things sierra! May take you up on the skim will try and get them to you before I go on holiday.
Edited by unclechief
Share this post
Link to post
1
Share this post
Link to post
