nelmo
Area Secretary
Everything posted by nelmo
  1. I bought these cosworth calipers http://www.rallydesign.co.uk/product_info.php?products_id=13593 and they are advertised as including carriers but they are not a separate item - they're forged into the body of the caliper (unless I've also got something wrong - my kit hasn't arrived yet), so you may not be able to buy separate carriers? I could be talking rubbish, of course...
  2. Continuing on my series of asking questions about ABSOLUTELY everything, front brakes next. While researching options other than refurbished Sierra calipers and disks from GBS (about £200), bloke at Rally Design suggested a Willwood pack they do for £320 - 4-pot shiny new calipers, supposed to be very good (although they would say that, of course). Up to now, I've managed to avoid paying more than i have to but the Willwoods do look good and shouldn't skimp on brakes, i guess? Opinions?
  3. nelmo
    Gbs Shocks
    So did you get them from GBS? If so, do you know what model no. they are?
  4. nelmo
    Gbs Shocks
    Yup, those are the ATRs and that is the price. But they also have a cheaper set for £400 on their website and i just assumed they were GAZ - no mention of brand name on the website.
  5. nelmo
    Gbs Shocks
    Ah yes, i remember them showing me the workshop - i thought that was just for the higher spec ATR jobbies. Ok, no probs - I'll stick with the ones they make....
  6. nelmo
    Gbs Shocks
    Sorry to ask on here but can't seem to log on to the GBS owners forum... Does anyone know what size/type/model no. of Gaz shocks are used on the GBS? The GBS website is, as for everything, useless for detail like that (probably because they don't want us to go and get the same parts cheaper ssomewhere else )
  7. First build and need some trestles. All the ones I can find only quote a max load of 150-200 kg (not sure if that is per trestle or per pair) - is that enough for the chassis and up to rolling chassis? If so, any preference for wood, plastic or metal?
  8. nelmo
    Cube Fuel Pump
    Ok, thanks all...
  9. nelmo
    Cube Fuel Pump
    GBS are offering a cube fuel pump for £45 but there are loads on the Bay for £12or so. I'm happy to pay £45 if the GBS one is any different to the cheap chinese ones - any one know if they are any good? Example below: http://pages.ebay.com/link/?nav=item.view&id=171436731218&alt=web
  10. nelmo
    Caliper Painting
    Ok, thanks all - so no need for a primer of any sort? What is etch primer for (i keep seeing it mentioned )?
  11. I've had a new pair of calipers delivered. They are lovely and shiny now but bare metal - should i paint them? I want to anyway but what is the process - some sort of primer/undercoat first? Do i have to strip it down or can i just mask off the rubber bits? Hammerite or special paint of some sort?
  12. I thought I'd read that emission tests at IVA were not as strict as an MOT? I ask this because there is a thread on the GBS forum of owners struggling to get through the MOT - you have to fit a lambda sensor and get a special emissions map for the ECU which isn't quite sorted yet etc, etc. I'm not bothered about resale value...can i choose an age-related plate? For example, I'm getting a 'new' Zetec engine which could only have been built about 2004. Could i request an 04 plate, maybe?
  13. Reading the pinned thread about MOT emission tests, it would seem to me that having a Q plate will make the MOT a piece of cake. Even though I hope to qualify for a new plate, can I opt for a Q plate and ensure simple MOT tests in the future? Or is it not that simple?
  14. nelmo
    Gbs Rear Brakes
    Included, according to that Rally Design link? So they are the right ones?
  15. Are these cosworth calipers the same as kit spares sell (well, i can't find them on the website now but I'm sure they do them): http://www.rallydesign.co.uk/product_info.php?products_id=13593 I assume they're ok - or is there a reasonable cheaper alternative?
  16. nelmo
    Fire Pit
    My sister has one and they work really well because all the holes provide excellent air flow for the fire. Not sure if you could design a better firepit if you tried
  17. nelmo
    Engine Ecus
    Starting my first build soon with a Zetec engine. GBS only seem to offer an Emerald ECU for £700 . The Megajolt seems much cheaper - is it any good? Is there any other make i should consider? Thanks.
  18. nelmo
    Fuel System
    I should just have you 2 on speed dial Got the list, Richard, which is why i was confused - it has an LP pump, filters but the 'fuel kit' doesn't. I think I'll do what turnipfarmer says - don't suppose either of you can confirm if the eBay swirl pot will fit the GBS? There's also a 1.5L version which is 200mm high - is that better? Thanks guys...
  19. nelmo
    Fuel System
    First build of my GBS Zero and lots of questions. .. GBS have sent me a quote of £400 for a 'fuel system kit'. On questioning them, this includes the following : Pump & filter mounting Kit Fuel injection Pump Fuel Pressure Regulator Swirl pot and mounting bracket Pipes and various brackets. Now, I could be wrong but this doesn't seem to be a full kit IMO. Don't I need another pump and a filter? Do I need the swirl pot or is there a cheaper alternative? TIA.
  20. Thanks Richard - i may take you up on that... :good:
  21. nelmo
    Engines 101
    I know i worked out a budget before i started which must have included these bits but it's a bit shocking when a box of electronics costs almost as much as an engine! Thanks for all the replies :-)
  22. Went for this - low profile and a little more expensive but better reviews: http://www.amazon.co.uk/gp/product/B00521RGXG/ref=s9_simh_gw_p263_d0_i1?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=center-2&pf_rd_r=14YX60WH0T84S6RVZE2Q&pf_rd_t=101&pf_rd_p=455333147&pf_rd_i=468294
  23. Tooling up - are these any good or cheap muck? http://pages.ebay.co...0534429&alt=web (Don't know whythat link is going to the US site....)
  24. nelmo
    Engines 101
    Some very basic questions - I'm about to start my first build and I'm confused about what i get with an engine. I plan on using a basic 2.0 L Zetec - nothing fancy. I see lots of blogs and posts about aftermarket throttle bodies, ECUs etc. When i look at places selling engines, none seem to explain exactly what you get for your money - would i expect an engine to have an ECU of some sort? Manifolds? Alternator? Pumps? Flux capacitor? What should I expect to have to buy extra? Sorry for stupid questions....
