710 -
Everything posted by miikae
Oh did they really , good to tell you have not done a search , i guess you kow best then eh . How is it that they do just you what you wanted , only trying to help . As i found it . £39.56
Hi Dave , Have you checked that the starter solenoid contacts are not sticking as badly worn burnt contacts can weld themselves together , Mike
Hi Paul , was the Bmw driver reported for being on the phone by any chance ? As if he was reported and was prossecuted for this you may be able to claim for more than the loss of the car , its just a thought . Mike
Wire colours may vary depending on which wireing loom was used . If indoubt connect 30 first Bat + and then check with a meter or a light bulb which terminal gets power when the switch is operated . 30 bat + 50 start 15 ign R acc Mike
I like it , the old ones are the best and can still bring a smile to one .
When you buy plates from the DVLA they do tell the buyer that it is ilegal to alter the spacings and that the new plates you have just bought could be confiscated from the buyer and with no refund of the price you paid for them , so your mistake your loss no refund . So no excuses excepted , you have been warned !! Mike
The ebay seller of those boots is a good supplier of lots of hard to get motor spares you only have to ask him , i have know him for well over 30yrs now and bought most of my stuff from him in that time , He writes best man speeches too as his ebay name implies . Mike
Donor parts from one of these may be of use here . New System: Electric Parking Brake A recent variation is the electric parking brake. First installed in the 2003 Lincoln LS, electric brakes have since appeared in a number of vehicles, including the Audi A6 and A8, BMW 7 Series, Jaguar S-Type and XJ, and the 2006 Volkswagen Passat. Two variations are available: In the more-primitive 'cable-pulling' type, an electric motor simply pulls the emergency brake cable rather than a mechanical handle in the cabin. A more advanced unit uses a computer-controlled motor attached to the brake caliper to activate it. Mike
Why not go hydraulic , use a line lock valve that way it could be done manually or even electricaly opperated if so required . But not certain of SVA requirements regarding this approach as they may want a separate system as it is supposed to be an emergency brake afterall . Mike
Just measured my old 4 speed box 30 1/2 " from bellhousing to end of tail casting plus 17mm of 25 spline shaft , not certain of the total length of a five speed type 9 but i thought that it was approx 2-3" longer i may be wrong here & getting confused with the mounting being further back , i had no problem changing from a 4 to a 5 , just moved the mounting back and used the same propshaft as it was a perfect fit . Mike
id be more than a bit wary if you see what he's been buying lately !!!!
Pleased that you got it sorted in the end Tak , you will just have to put it down to experance i suppose , but at least you didnt loose out and he got a flea in his ear . These things are sent to try us and they certainly do at times . Mike
Hi Tak , You could leave him neg feedback stateing item not received and when and if you do receive it , you can always post an addition to your feedback comment as i had to do this last year and it speeded everything up as he soon saw that i got my item , lots of appoligies too to clear his name . Mike
Nice one Ian , You just reminded me that i have many full lengths of Dexion plus nuts bolts and corner pieces lodged in the garage roof (been there for 15 years ) , been wondering how to stack the tool boxes to get them off the floor . So thats another job pending . Mike
Hi , I had the same problem a couple of months ago i was mad too , but i phoned them and paid the excess , got them to deliver it as i was not intending to trek into town to pick it up as it would cost me at lot more to go by car .(a 40 mile round trip). Our local postie has also done the same for me in the past with revenue due items . Mike
The story so far --stripped it down checked all connectors , connections etc , (as earlier in the day i noticed that as soon as it was tapped or moved it locked up ) , put it all back together and now it wont even turn on , it is getting power as the front panel lights work , the bios bat is down to 2.5 v so not completley dead , i am thinking now the power board could possibly have a fault , so the back off again in the morrow and check it all over again . Mike
It is in fact a model PS610E , SP6100 series so quite an old one i beleive 5 years old maybe . So about anything could be happen now aarrgghh , I dont think my lad has much patience these days so he brings it to me to sort out , the old man !!! Mike
The battery could well be on its way out , but all those contacts on it dont give one too much confidence of all making a good connection . The rear power connector was replaced a few months back and seems ok at the moe . It now seems to run longer running on the battery only ,before it locks up and with the power cable disconnected , possible due to it taking longer to warm up without having the higher power settings running whilst on battery . Mike
Hi , it lasted about 20 mins this time before turning itself off , i will have to check to see if the fan is ok . I had thought that possibly the BIOS bat may be on its way out as it must be at least 5 years old if that means anything these days . When it goes off i have one green and one amber light still on . Many thanks to you both you have been a great help , so time to take the back off now and hope there are no dead mice in there !!! Mike
Great stuff Many Thanks , its back on now , so i will have to see how long it goes before it freezes again , is there a cooling fan in these a i cant hear anything running , When it boots up it does say sum check bad & bad bat RTC , how can i sort this i wonder ? Mike
Help needed for my lads laptop as it wont turn on at all now ,(it was locking itself up after about 10 mins of being turned on ) i think that the bios settings may have been altered , if that is the case then how can i reset the bios so that it will at least turn on . Any ideas anyone . Mike
Cant see how it would be any good as it would be being dragged by the air flow until one lifted off the throttle and only then would it give a little boost , so keep blipping the throttle maybe he he , but what do i know about windmills !! Mike
I will be keeping my eye on that as its only a stones throw away from me and some spares wouldnt go amis .
