Knock-on
Everything posted by Knock-on
  1. Does anyone know what the regs are for a seatbelt being threaded through a seat are? The holes in mine are a bit narrower than the welded mounts on the car. As it is, one is nicely lined up but one is slightly out of alignment. Should I angle it off and try rewelding it which may look a bit of a bodge with my welding or do they not have to line perfectly up?
  2. There's been a few different ones. Pretty sure Matt Neal done a couple and you can't mistake that Lanky bugger. How he gets in a Touring car is beyond me. It's long been suspected that Ben was the Stig but I would be surprised if he let it slip. Great advertising for TG though
  3. Speak for yourself. I remember as a kid those bloody gliders coming over the Manston Caravan Park at about 50ft. You could hear every word the instructer was saying to the young ATC lads.
  4. Knock-on
    Possible Virus
    However, there is a nasty worm going around at the moment called confiker so make sure your OS and Virus updates are up to date. As a general rule. If you send on chain letters, jokes or warnings to people, it's good practice to remove the sending history and forward as BCC to try and avoid ending on spam lists.
  5. Knock-on
    Flipping Banks
    http://www.moneysavingexpert.com/ Go on the forum as there's lots of helpful people.
  6. http://cgi.ebay.co.uk/Ford-RS-Turbo-Engine...%3A1|240%3A1318 There's only 5 hours left but if anyones interested in a cheap motor.
  7. Knock-on
    Help Needed
    There's an optimum but not a limit. I heard a whisper that MK engineering are putting together a kit with a V10 Viper engine for some idiot. You could never use a fraction of the power and it would handle like a slug.
  8. Stealing a Pinto sump is easy. You just need a Balaclava, socket set..... (I'll get my coat )
  9. 25mph. Hooligan!!
  10. Knock-on
    It Lives!
    Well done although I don't think that exhaust bracket is SVA compliant
  11. I don't think the age is a worry although obviously a lot of bits may need replacing or rebuilding including the engine. I think the price is wayyyy off though. I picked up a part built with almost all the parts for just over a grand a couple of years ago and as has been said, we're not in the most optimistic financial climate
  12. I saw it earlier today and nearly choked. £9k is being a little optimistic I think. About £3k optimistic
  13. Knock-on
    Sva
    Yep, the law according to Sod strikes again.
  14. Couple of quick questions. What build photo's does everyone recommend are taken and what if i don't have all receipts / proof of disposal of the donor vehicle etc as I purchased mine as a part built? Cheers
  15. Is there any minimum standard a car needs to be in to be SVA'd? If I can get something that is 95% complete, can I get a nice long failure list and fix those over the next 6 months or will they refuse to test it?
  16. Set on ebay for about £100 less than retail at the moment. Just search Robin Hood Kit Car.
  17. Slab of Kendal Mint Cake strapped to a St Bernard and pointed in the direction of the M4. Just try and hold on until Snorbitz gets there!! We are just about holding out in deepest darkest Surrey. Ventured outside but beaten back by the withering sunlight and high temperatures. Anyone got any sunblock?
  18. I would echo what everyone else has said. I have had a part built for a couple of years and in that time, have had to take most things back to basics. Just finishing off the last structural bits and bobs now but still have a lot to do. Rule of thumbs I discovered. 1. If someone tells you it's 95% built and just needs a good weekend to get it ready for SVA, offer to pay them £100 for a weekends work to finish it. If not, assume it's 5% completed and needs 95% of reverse engineering. 2. If someone tells you that all the bits are there to complete it and it looks pretty much together, budget for another £500 for rivets, seals, bolts, plate etc. 3. Enjoy it. It's great fun but lobbing one together over the winter may be a little optimistic. I'm looking at 3 years from getting mine to have it through the SVA and that doesn't seem too bad. Some Hoddie builders have been known to go through a marriage or two before completing their project. Good luck. There's plenty of knowledgeable people on here that have a wealth of building experience (of which I am certainly not one ) KO
  19. http://cgi.ebay.co.uk/Robin-Hood-2-Litre-8...A1%7C240%3A1318 Hi Mart You seem to have accidentially put a reserve on? Good luck.
  20. I thought for the SVA, it needed full tadpole rubber. Doesn't matter, I have some now so an easy job. I have got some DVD's somewhere but can't find them. Mind you, watching them delicatly enlarge a hole with the aid of a club hammer might have encouraged me no to look too hard and rely on the advice on here for the few bits I needed Will try and find them again at the weekend.
  21. You'll have to forgive me Chris but I'm doing a lot of reverse engineering on this car as I bought it pre-bodged and am finding things may not have been constructed as they should have been. At the moment, I have 3 components. 1. The side sheet 2. The floor sheet 3. The Chassis tubular frame. The section in question is from the front wheel to the rear wheel as illustrated in the above pictures. At the moment, the 2 panels are affixed for about half the distance from the front wheel back. There they part company and a increasing gap appears until the pannels finish by the rear wheel arch. They are approximatly 1" apart at the rear. Fortunately, I have had to remove the rear arches as the previous incumbent neglected to put tadpole rubber between the arch and side panel so if I have to take off the sides and rebend, I can. Do I need to do this?
  22. Knock-on
    Spare Wheel
    Has anyoneone got a spare Aray wheel knocking around? I have a spare Alloy but if I can get a reasonable cost spare, would like to keep the set the same. Cheers
  23. Knock-on
    Club Magazine
    Haven't received mine yet but only rejoined a couple of weeks ago so probably last on the list for dispatch
  24. So, the outside panel is bent under the tubular steel back on itself and affixed to the floor sheet? That's what I was planning but was going to nut and bolt it rather than rivet it for strength. As for the angle iron, was going to run that further along the plate to get 2 bolts in it at the end although with the front one, was just going to drill through the chassis and bolt a M12 straight through.
  25. Hi Chaps Can someone post me a couple of piccies of the underside edge of the car by the mounting plate for the seat / rear axle. Basically, I just want to see how people have fixed off the side pannels and seat supports to the frame. Cheers. KO
