Three Cylinder Pinto, Any Ideas
I can drop you one off Friday ,im working in wombwell through the day . If no one else has one. Working all day sat so cant come over for the work.
cant make sat was hoping to but this weekend bad weekend couple of cars to do here :( .ivan my dad had same issue with his ng kit it was no fuel getting to the plugs he is running two carbs but that went down on 2 plugs not one.
could always swap carbs over see what happens then.. would let you know if it was a carb issue.
The South Yorkshire mob should get you sorted one way or another Ivan.
Best get Andrea to knock up another load of chilli for them though.......
Looks like Ivan is coming across to mine on Saturday for the engine/ clutch re-fit. He is bringing his kit along, so we can have a good poke around in his engine bay to see whats going on. Only thing I don't have for Ivan is a timing light so if any of you who can pop across can brig one would be a big help.
Planning to start at 10ish again
andy should have the rhocar one if someone can get it off him
aye, still have it. Not sure if i'm going out to play on sat yet.
ivan don't turn your back for a second the engine will be out in bits on terrys floor.
and that's just so he can polish it
