I Just Cant Stop Tinkering
tractor
just been tinkering again just had DTI gauge out set correct TDC then fitted verneir pulley on exhaust cam and advanced it 5 degrees just got to wait for the rain to stop to test it but at tick over purrrrs nicely
I played with the cam timing on my XE (very carefully!)
I found that advancing the cam(s) pushed the power band higher in the rev range, but
did deliver a few more horses.
It also made it totally useless round Lydden.....it refused to pull out of corners.
Retarding it slightly (2-3 degrees) widened the power band, the power came in about 500 rpm
lower.
BUT BE CAREFUL!!! or pistons & valves may kiss.....& not in an attractive way!
whilst setting the the verneir pulley I didn't tighten up the centre bolt and I turned engine over by hand and didn't notice exhaust cam wasn't turning but the engine turned over !!!!! I would have expected it to lock up but it didn't !!!!!!
And probably reduce the BHP figure.
I'd start with 2 or 3, see what happens, than go to 5
BUT ONLY IF YOU THINK ITS SAFE !!!!!!
My tinkering only came about because the exh. cam vernier came loose
& sat at about 5 degrees advanced without me knowing.
But the car became a pig to drive......no grunt until 5.5K then all at once with a bang.
After I set it to the cam grinders figures, & it became very tractable, I retarded it a bit more
& got even more torque, but the engine lost all its camminess? & power delivery became very
flat.
I did similar but deliberately. Had read on the internet that up to 6 degrees retarded was 'safe' for the exhaust cam on the ST. Tried it on the rollers. Lost a couple of top end horses but the torque gain lower down more than made up for it. When I next had the head off I found the valves had been touching the piston tops and then remembered the head has been skimmed. Amazingly no other damage done and I have backed off to just 4 degrees. Makes quite a change in the engine note and more tractable. Don't notice the top end loss as I have too many horses anyway! :)
Chris, have you ever considered it to wear as set of mittens at least one day a week.
You are going to wear your tool box out the rate that you go.
