Supercharger On An St170 Engine
Have you seen my diagram on bellmouth radius effects on airflow?
Another one of over thinking moments!
  • Replies 76
  • Views 20.6k
Most Popular Posts
  • Longboarder
    Longboarder
    I would agree on N/A intakes and throttle response is crisper the closer to the valves the throttle is but I don't think there is much difference in flow on supercharged engines. A single large body t
  • richardm6994
    richardm6994
    None whatsoever......what I do is measure the belt path using the wire with the tensioner set at either extreme of its tension position .....so in this case the belt I was looking for was somewhere be
  • richardm6994
    richardm6994
    So the charger inlet is now finished and added a bit of strength back into the chassis where the original brace has been removed. Next job is now to fit all of the fuel system back into new locations
I came across this one (can't remember where) but seems to give a good indication of what shape to strive for...
F225F970-EB8F-498A-95DF-E8DD87C609D9_zps
David Vizards book, How to build horsepower. Vol 1
Well i hope so but i dont have my copy here to confirm.
That's the one
What I mean is that's the diagram.
I found it interesting that the stubby profile gave such good results.
The full rolled edges are good and sharp edged trumpets not as good as one might think.
But that said a rounded profile is always better than a sharp edge.
Edited by Snapperpaul
Because it acts as a wing. The air has a greater surface area to "attach" itself too, therfore you get a greater charge on entry.
All the pics I have ever seen are about air being sucked. Naturally aspirated. When it's blown I imagine it's a bit different. Same smooth airflow principles, radii, port matching etc.
  • 1 month later...
It's been a while since I updated because I've been busy machining the supercharger outlet.
Unfortunately, the first effort (which took over 2 weeks) went in the bin because it didn't turn out as well as I'd imagine and it was better to just cut my losses and start over.
I'm much happier with mk2 and it's completion now signals the beginning of the end as all the bits are rebuilt for the final time, painted and fitted onto the engine....not long now.....
972D4731-EB45-4439-B4ED-AA8F3755841C_zps
D149A1E8-BC8A-4F11-B575-8A9E3026FB47_zps
7D746471-3C82-4860-93F9-C07DF2378D25_zps
3514ACD3-5F42-42C4-A6A1-7B8D3AEB617B_zps
A765D690-119B-4109-A18A-649C79E6BE1E_zps
Edited by steamer
That is just pure SEX :wub:
And now time for the kitchen worktop photo of the finished supercharger....
6DD27FEE-9B71-4628-BE0C-0E929607BD4C_zps
Sorry but Ive just come in my pants
Richard you should only post pictures after the 9pm watershed.
Looks lovely
Here you go Andy, a couple more just to finish you off....(after the watershed lol)
Timing belt cover before and after modification
E2C7B363-2EAF-42DD-BD6E-05210676780A_zps
And here it is all in the car (very tight!!!)
2E11E060-DB89-4D0B-9CA3-41AB3CDDF933_zps
Tight n sexy !!
Thats some amazing work
All going good so far.
https://youtu.be/ePJ14qLrypI
The edge of the belt is black and white which gives the optical illusion on the video that the belt is jumping on the crank pulley, but I'm really pleased that the belt is running perfect with no signs of wobble.
Obviously as the water plumbing is not done, I could only give her a few seconds of running to check things. Next job is to sort out the new rad and intercooler so I can run her up to temperature properly and put her through her paces before having a tidy up in the engine bay.
CEFE327F-CFAF-4ADC-BF0D-7899DE018DEB_zps
F347E791-BCE1-4711-A39B-541A2D0C0F96_zps
Edited by steamer
Great progress Richard it's sounds good
