Hi all.  Hope everyone is safe and well.
I need some help from Zero owners. I have the zero standard chassis, so if anyone can help, that would be great, to make sure I get the correct parts and mount them roughly in the right area.
I have finally given in and am moving from the aero screen to a full windscreen.
I am measuring up for wipers and need some measurements as follows:
1 - Distance from screen to wiper spindle hole (gap between screen and wiper spindles)
2 - Wiper spindle hole centre to car centre line
3 - Wiper arm length
4 - Wiper blade length
Many Thanks
Steve
Hi
Does the scuttle have the pre cut holes for the screen brackets?
If So
https://www.dropbox.com/s/wctjey9hf0d7guj/2013-02-06 15.44.52.jpg?dl=0
Get kit
https://www.dropbox.com/s/30ar21imqpzqxyc/EXTWPS2_IMG_2681.jpg?dl=0
Fit kit
https://www.dropbox.com/s/45gsnuy1ev66d9e/IMG_5849.JPG?dl=0
Sorry, still looking for measurement to cut tube, think they are in the manual somewhere
Mod wiper arms
https://www.dropbox.com/s/dl8pm4g7rv757q7/wiper arm build.docx?dl=0
Shout if you need anything else
Regards
Here you go! CL reference is the tab on the back of the dashboard/scuttle. All measurements are mm.
One thing I would say is remember there's a certain amount of adjustment in the wiper blade (for me at least) they can be varied in length and bent (and they needed it!)
Edited by brumster
8 hours ago, knights_templar said:
Hi
If So
Get kit
Fit kit
Mod wiper arms
Regards
Thanks KT, already been given the 1st picture with the measurements.  Good and useful info.  Must admit I have been looking at the Car Builder kit which looks the same and has options of sweep available, plus is about £50 cheaper!
Thanks again
Thanks Dan. Confirms a lot of the measurements.  Just out of curiousity, why park on the passenger side?  Most I have seen park on the driver's side?
Steve
This layout gives way better clearing of screen for the driver, it gets up nicely on the right-hand edge (as the driver sees). I spent a long time carefully trialling and positioning the blades to work out where the holes would go (my car wasn't pre-drilled, thankfully). I was so thankful of these at the Wales weekend the other year - they really made the whole weekend so more "pleasure" than "pain" :). Standard Defender wiper motor in terms of sweep angle/gear.
Cheers Dan. Gives me something to think about!    Will have a play around this weekend. Always good to get another perspective.
That's quite weird - my holes are symmetrical from that CL (2015 GT chassis, holes pre-drilled) so I had a choice which way to park them. I tried them on passenger side but seemed a bit better on drivers side - not much in it.
Edited by nelmo
Mine park on drivers side. I was told by GBS they are centralised so the same panel fits for left hand drive cars.
Thanks all.  I am luck enough that i dont have an holes pre drilled.  This means i get a choice.  Having done some mock up i think i will be copying Dan and go with the passenger side park.
It seems to sweep a bigger area of the drivers side and higher on the screen too.  Having a blank canvass means i can fit the screen and then tweek the wipers to fit.
What could possibly go wrong!!
