I'm after the slip ring and sprung pins that goes on the back of the steering wheel and had two circular brass contact areas for the horn wiring.
Edited by richyb66
Just had quick search, looks like your looking for rocking horse poop. Can't believe when I built mine i got new carbon contacts from Ford and now there's nothing? I do have the old contacts but they where too worn to reach the slip ring in my Mountney wheel. You can get old MG or triumph rings and spring contacts easily enough, they might be possible to adapt but they are single pole so you would need to earth through column?
I could earth through the column and adapting another ring is an option but if I can get something that's a direct fit, I'd like to save myself some work.
