Im after a short steering wheel boss to fit a Sierra steering column with a mountney wheel, as my boss is approx 100mm, or a weld on quick release type
Can anyone help
I have just purchased a 12" 120W electric fan to try to aid cooling my 2.0 Pinto, I am fitting it on back of radiator between radiator and engine.
Bit of a daft question but... should it be wired to push air back towards radiator, or to pull air through radiator into engine compartment.
Hi
Is there any more info about the Smallways meet this month and directions how to get there
from Durham way, is anyone meeting up to go down?
Thanks in advance
Harry
Hi
Before you hand any cash over make sure car is correctly registered on logbook as Robin Hood, not Sierra sports or any other rubbish otherwise it hasnt had IVA test and is only worth a fraction of on the road price vehicle.
I'll be lol nearly done just a couple of probs to sort tomorrow, No speedo magnets on yet as will have to get back under to change propshaft
See you there
Thanks for help it is much appreciated, what size resistor do I need and does it go on 12v ign live side or thin wire from alternator side, also my lamps are LED so I was going to put a small bulb holder with a 2w bulb between lamp & alternator
Whilst fitting ETB gauges I decided to fit savage switches and warning lights, all work as they should except the battery warning light wont go off when engine started.
I connected the wire that previously went to my digital gauge unit to the + side of the savage switch and the other end to earth but it stays illuminated when engine started.
Can anyone point me in the right direction
Has anyone fitted a transit indicator stalk as a replacement, if so have you got a wiring diagran for the pins on rear of switch,
Thanks in advance
Harry
Thanks guys
I'm now sorted, took lot out and wheel boxes are seized solid, I've ordered 2 from CBS so with cleaned up bundy cable, replacement motor and new boxes it should be another job off jobs to do list lol
Many thanks for your help
Harry
I am after advice on a couple of problems regarding my wiper motor on my S7
I have purchased the wiring plug to wire to column switch but there are 3 wires coming out of motor body and I presume they go to the 3 contacts on the park switch but can anyone identify which wire goes to which terminal (see pic)
also the wipers are really stiff when I pulled the cable which drives them through wiper boxes should this be really easy to pull and if so how do I remove from car to grease/lubricate
Thanks in advance
Harry
The front cycle wings on my S7 have seen better days and started to crack/craze the wheels are 16 fitted with 195/45/R16 tyres can anyone recommend a supplier for wings either in yellow or primer as ones on flea bay seem too small
Thanks in advance
