nelmo
Everything posted by nelmo
  1. nelmo
    Iva Booked
    Yeehaa!!! A pass (just about) - details in blog....
  2. nelmo
    Iva Booked
    Thanks guys, the 'kink' he saw was minimal, he was more concerned with the graze on the side of the pipe where the flaring tool marked it. In fact, he was umming and aahing about failing it at all on that - at the end, he actually suggested I just cover it up so the next tester can't see it! Which is what I've done using that Silweld tape stuff :-) I might try the garage idea for the brakes - what did he actually do? Grind your pads down? @Richard, thanks for the offer but I don't think I've got time to get them off you...
  3. nelmo
    Iva Booked
    A bit of a spanner in the works...I phoned up to book a re-test and was offered either this Friday or July 31st! I just can't wait so long for the re-test so I'm going for Friday. This means no time to wait for deliveries so no pressure reducer or brake balancer. However, as the difference between front and rear was marginal (35 rear, 34 front - I have no idea what those numbers refer to), I only need a small improvement up front to sort that out - I'm hoping a re-bleed will be enough. A couple of long evenings ahead...
  4. nelmo
    Iva Booked
    Simple Ford master cylinder, vented discs front, solid disk rear. Any ideas how to make the rear weaker?
  5. nelmo
    Iva Booked
    Well, today was the day and, sadly, a fail but nothing serious. Full details in the latest page of my blog (link below).
  6. No problem - although very jealous of you retiring at 44 I think I was very lucky with my electrics - they mostly worked first time. I would recommend Richard's blog (link from mine) - more technical than mine and he knows his electrics...(although always tricky to explain electrics)... Good luck with the project...
  7. With respect, I would have recommended a lot more research before you took the plunge. Buying a part-built project is probably harder than starting from the beginning as you haven't built up any experience. Is your problem with how to install the panels or where they go on a 2B? 'How' is quite easy (see my blog - link below) but the 'where' I can't personally help you with. I am in Reigate in Surrey (about an hour from you) and you're welcome to pop round (PM me) - I've got my IVA next week, so not free this weekend to get to you...got some last minute jobs to do.
  8. nelmo
    Gbs Open Day 10/6/17
    Easy to say if you only live 50 miles away... would you have gone for the day if the factory was in, say, Newcastle?
  9. nelmo
    ... Er...you're one of those Zero owners - isn't it just that Zero owners also happen to be RHOCAR members? :-)
  10. nelmo
    Tempted
    What is Range Rover reliability like these days? I remember looking into getting one 5 years ago, registered on the owners forum and the horror stories scared me off - almost everyone on there had problems (but they did still 'love' their cars). I was driving behind a brand new LR Discovery a few days ago and one of its rear lights (LEDs) was flashing on/off. Less than a month old and warranty claim already :-o Personally, this is a much better bet: http://www.autotrader.co.uk/classified/advert/201703263712476?advertising-location=at_cars&price-to=27500&postcode=rh20ss&sort=price-desc&radius=1500&model=RX%20450H&make=LEXUS&onesearchad=Used&onesearchad=Nearly%20New&onesearchad=New&page=1&advert-type=featured-listing I have the old model, 130k miles so far, not put a tyre wrong...
  11. You just need some of the main parts to have a known history, the engine being a main one and you're fine there. If you get a Sierra doner with a V5, also good but I believe if you bought reconditioned bits (gearbox, diff etc) and had invoices for them, that would also be fine. If you're thinking GBS, give them a call - they can give you a definitive answer.
  12. Ah, across the width - that sounds a better idea...
  13. Well, looks like I'm going to have to raise my seats for IVA because the harness slots are too low so belt run isn't straight. I was thinking of just using a pile of penny washers between runner and floor plate washer but it doesn't feel right - my seat will effectively be balancing on them. Is there a better way of doing this or will that be OK?
  14. Arrgh, you're right! Why didn't I realise? Many thanks... and I'll get those bigger washers.
  15. Thanks guys - so do your seats still wobble a bit or are they rock solid?
  16. I've got Intatrim seats on universal runners but they're quite wobbly. I think this is because they are effectively sitting on the 4 nuts that go through the floor, rather than being flat to the floor, if that makes sense. What I mean is, after fixing the runners to the seats, I put a bolt through the runner with a nut to tighten it against the runner. Then that bolt goes through the floor to the final nut and washer underneath. If I don't have that nut, I can't tighten the nut underneath but that nut is, i think, causing the wobble. Is this normal? Have I got this right or am I doing something wrong?
  17. nelmo
    Jensen Healey
    Wow, great job from welding and no engine in 6 months! Any more pics and details of the work?
  18. nelmo
    Iva Booked
    Thank you all... ☺
  19. nelmo
    Iva Booked
    OK, scary days - IVA booked for June 19th at Yeading in West London. I chose Yeading just because it is physically closest to me - anyone know if this is a bad place to get tested (I still have time to change it)? One person on the Locost forum said they were fine but any other opinions welcome.
  20. Can I ask how much that cost?
  21. Still not been able to get this done so I am considering welding on a separate plate. I know nothing of welding - can I stamp into ally and then get that welded onto the steel chassis? I vaguely remember being told that ally doesn't weld well...
  22. Why dodgy? Sold for a reasonable looking £2.3k - weird rollbar
  23. nelmo
    Surrey Top
    Sadly, Intatrim don't do hoods anymore.
  24. nelmo
    Surrey Top
    I've just ordered my seats from them - didn't know they did tops. I'll call them, thanks...
  25. nelmo
    Surrey Top
    That does look great tractor - can I ask where you got it from or did you do it yourself? Do you find it keeps heavy rain out while on the move? Just wondering about the big opening at the rear...
