nelmo
Everything posted by nelmo
  1. nelmo
    Seats
    Hmm, I am on the wide side...darn... (Thanks for the offer, Fossett, but I don't want GRP...)
  2. nelmo
    Seats
    Does anyone have experience/opinion on these? http://www.ebay.co.uk/itm/PAIR-UNIVERSAL-NARROW-BUCKET-SEATS-KIT-CAR-INC-WESTFIELD-CATERHAM-LOTUS-/301613273707?hash=item46398d526b They look rubbish, to be honest but I'm struggling to find much choice of narrow seats ( Any other suggestions? I don't want GRP (even with foam pads), slotted headrests and they need to be I stupidly already bought a pair that are 50cm at the base, which just fitted ok UNTIL I fitted the seatbelts - the seatbelt bolt knocks an inch off the width.
  3. Ah, that's possible - I remember 2 wires going into 1 of the bulbs but didn't think to look at the filaments - I'll check it tonight - many thanks...
  4. While preparing to install my rear light clusters, I may have ended up getting the lens units swapped around. In each unit, I have a 5W bulb and a 21W bulb - is there any standard for which of these must be the brake light and which the indicator? Despite searching the web, I cannot seem to find an obvious answer to this seemingly trivial question (and nothing in the IVA manual either).
  5. Just to clarify, I didn't make them up, I just copied them from somewhere else....although I can identify with most of them
  6. Thanks Richard - I have stamps and used them OK on the VIN plate, just not much good on the chassis rail. Hmmm, separate plate just bonded on? Like you say, IVA man might not notice as it is under the side panel...bit risky though. There is a local company who do VIN plates and may be able to do the chassis rail but the problem will be getting to them. Don't want to hire a trailer just to get the car 3 miles but if I risked driving, I would have to drive past the local police station to get there
  7. Pinched from a FB post: HAYNES' MANUAL - THE REAL MEANINGS For those of us that have ever used a Haynes Manual in attempting home maintenance of a car. For those who have not used a Haynes Manual, these are the books aimed at car-owners who want to fix their own cars and which keep qualified mechanics in paid employment putting things right afterwards. They are chock full of photos, diagrams and step-by-step instructions which are obvious if you are a fully qualified motor mechanic, but which are frighteningly sparse on detail for the average Joe in the street who wants to change a set of spark plugs on a 1981 VW Polo .... Haynes: Rotate anticlockwise. Translation: Clamp with molegrips (adjustable wrench) then beat repeatedly with hammer anticlockwise. You do know which way is anticlockwise, don't you? Haynes: Should remove easily. Translation: Will be corroded into place ... clamp with adjustable wrench then beat repeatedly with a hammer. Haynes: This is a snug fit. Translation: You will skin your knuckles! ... Clamp with adjustable wrench then beat repeatedly with hammer. Haynes: This is a tight fit. Translation: Not a hope in hell matey! ... Clamp with adjustable wrench then beat repeatedly with hammer. Haynes: As described in Chapter 7... Translation: That'll teach you not to read through before you start, now you are looking at scary photos of the inside of a gearbox. Haynes: Pry... Translation: Hammer a screwdriver into... Haynes: Undo... Translation: Go buy a tin of WD40 (catering size). Haynes: Ease ... Translation: Apply superhuman strength to ... Haynes: Retain tiny spring... Translation: "Jeez what was that, it nearly had my eye out"! Haynes: Press and rotate to remove bulb... Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part and remaining glass shards. Haynes: Lightly... Translation: Start off lightly and build up till the veins on your forehead are throbbing then re-check the manual because what you are doing now cannot be considered "lightly". Haynes: Weekly checks... Translation: If it isn't broken don't fix it! Haynes: Routine maintenance... Translation: If it isn't broken... it's about to be! Haynes: One spanner rating (simple). Translation: Your Mum could do this... so how did you manage to botch it up? Haynes: Two spanner rating. Translation: Now you may think that you can do this because two is a low, tiny, ikkle number... but you also thought that the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you). Haynes: Three spanner rating (intermediate). Translation: Make sure you won't need your car for a couple of days and that your AA cover includes Home Start. Haynes: Four spanner rating. Translation: You are seriously considering this aren't you, you pleb! Haynes: Five spanner rating (expert). Translation: OK - but don't expect us to ride it afterwards!!! Translation #2: Don't ever carry your loved ones in it again and don't mention it to your insurance company. Haynes: If not, you can fabricate your own special tool like this... Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!! Haynes: Compress... Translation: Squeeze with all your might, jump up and down on, swear at, throw at the garage wall, then search for it in the dark corner of the garage whilst muttering "******" repeatedly under your breath. Haynes: Inspect... Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I thought, it's going to need a new one"! Haynes: Carefully... Translation: You are about to cut yourself! Haynes: Retaining nut... Translation: Yes, that's it, that big spherical blob of rust. Haynes: Get an assistant... Translation: Prepare to humiliate yourself in front of someone you know. Haynes: Turning the engine will be easier with the spark plugs removed. Translation: However, starting the engine afterwards will be much harder. Once that sinking feeling in the pit of your stomach has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs. Haynes: Refitting is the reverse sequence to removal. Translation: But you swear in different places. Haynes: Prise away plastic locating pegs... Translation: Snap off... Haynes: Using a suitable drift or pin-punch... Translation: The biggest nail in your tool box isn't a suitable drift! Haynes: Everyday toolkit Translation: Ensure you have an RAC Card & Mobile Phone Haynes: Apply moderate heat... Translation: Placing your mouth near it and huffing isn't moderate heat. Translation #2: Heat up until glowing red, if it still doesn't come undone use a hacksaw. Haynes: Apply moderate heat... Translation: Unless you have a blast furnace, don't bother. Clamp with adjustable wrench then beat repeatedly with hammer. Haynes: Index Translation: List of all the things in the book bar the thing you want to do! Haynes: Remove oil filter using an oil filter chain wrench or length of bicycle chain. Translation: Stick a screwdriver through it and beat handle repeatedly with a hammer. Haynes: Replace old gasket with a new one. Translation: I know I've got a tube of Krazy Glue around here somewhere. Haynes: Grease well before refitting. Translation: Spend an hour searching for your tub of grease before chancing upon a bottle of washing-up liquid (dish soap). Wipe some congealed washing up liquid from the dispenser nozzle and use that since it's got a similar texture and will probably get you to Halfords to buy some Castrol grease. Haynes: See illustration for details Translation: None of the illustrations notes will match the pictured exploded, numbered parts. The unit illustrated is from a previous or variant model. The actual location of the unit is never given. The best one I encountered was how to change a brake sensor in a Ford Fiesta Popular Plus. The photo showing the location of the unit failed to mention the crucial detail of whether the item was located in the engine compartment or inside the car ..... and the helpful photo of what the thing looked like didn't give the reader any clues! HAYNES GUIDE TO TOOLS OF THE TRADE HAMMER: Originally employed as a weapon of war, the hammer is nowadays used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing seats and motorcycle jackets. ELECTRIC HAND DRILL: Normally used for spinning steel Pop rivets in their holes until you die of old age, but it also works great for drilling mounting holes just above the brake line that goes to the rear wheel. PLIERS: Used to round off bolt heads. HACKSAW: One of a family of cutting tools built on the Ouija board princ iple. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. MOLE-GRIPS/ADJUSTABLE WRENCH: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETELENE TORCH: Used almost entirely for lighting various flammable objects in your garage on fire. Also handy for igniting the grease inside a brake-drum you're trying to get the bearing race out of. Some More WHITWORTH SOCKETS: Once used for working on older cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for for the last 15 minutes. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying. WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "F...." HYDRAULIC FLOOR JACK: Used for lowering car to the ground after you have installed your new front disk brake setup, trapping the jack handle firmly under the front wing. EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering a car upward off a hydraulic jack. TWEEZERS: A tool for removing wood splinters. PHONE: Tool for calling your neighbour to see if he has another hydraulic floor jack. SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog-doo off your boot. BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit. TIMING LIGHT: A stroboscopic instrument for illuminating grease buildup. TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of ground straps and brake lines you may have forgotten to disconnect. CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle. BATTERY ELECTROLYTE TESTER: A handy tool for transferring sulfuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought. AVIATION METAL SNIPS: See hacksaw. INSPECTION LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate as 105-mm howitzer shells during the Battle of the Bulge. More often dark than light, its name is somewhat misleading. PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper- and-tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round off Phillips screw heads. AIR COMPRESSOR: A machine that takes energy produced in a fossil-fuel burning power plant 200 miles away and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty bolts last tightened 30 years ago by someone in Dagenham, and rounds them off. PRY (CROW) BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 pence part. HOSE CUTTER: A tool used to cut hoses 1/2 inch too short
  8. I've tried stamping the VIN number but can't seem to make a decent impression (literally) on the chassis rail and I've tried engraving it myself with a Dremel, engraving bit and plastic stencil. First letter looks OK but 2nd one is rubbish because the bit wandered all over the place, even within the stencil (it's a letter 'V'). I've tried practicing freehand on a steel off-cut and the result is pretty horrendous. When engraving, should I be holding the Dremel like a normal pen (at an angle) or should the bit be vertical? Any tips/tricks to getting this right? (I don't have a welder, so doing it on a separate plate and welding that on is not an option).
  9. nelmo
    Hello.
    Welcome and great looking car!
  10. Thanks Mark....glad you enjoyed it.... :-)
  11. Should anyone be interested, I've changed the url of my blog; link in my sig below...
  12. Send them a picture of an old wreck, get cash, spend cash on your own car and then, when they come to ask for your finished restoration, just say you couldn't do it? Only kidding....honest!
  13. Yes, thanks Richard, I did find that exact post eventually and I've checked with Emerald and they confirm that Torque app will work - they also kindly sent me a link to buy their specific cable for it as well Looks to be a promising post-IVA project...
  14. I mentioned it because I happen to have a spare Android tablet hanging about Problem is, I have an Emerald ECU and there doesn't seem to be any software apart from their own... don't suppose you know of of anything?
  15. OK, gotcha - never realised the Pi had a screen option. Have you seen the MSDroid app for Android (http://www.msdroid.com) ? Looks to do a similar thing but for any Android tablet...
  16. Looks great - have you got more detail of how it works? Where is the Pi in that setup? What did you build to connect Pi to ECU, assuming you've had to do that?
  17. nelmo
    Kimbolton 9Th July
    How does this work - do you get sited together as a club? Or can we arrive individually? I'm hoping to have my car ready by then and it looks like a fun event but I can't commit until I'm sure I'll actually have a car to go in ☺
  18. Excellent, that's what I was hoping to hear.... :-)
  19. But if I register my car this year, presumably that makes it a 'new' car? I haven't used one donor but I'm planning on getting a Q plate (even though I could get a new reg).
  20. Has anyone seen the new Road tax rules? https://www.gov.uk/newvehicletaxrates Does that include kit cars, does anyone know? Specifically, I was hoping to finish my car about April/May...:-(
  21. Anyone know what the story is here? Was that 2 bike engines side by side? Didn't sound like any V8 I've ever heard and didn't rev like one either
  22. Very kind - I'll have a go at a design but I'm about as artistic as a hedgehog :-). I was hoping to give someone a rough sketch and let them do the techie stuff. But the companies that do that look like they'll want a decent quantity ordered and I only want 2. Many thanks but I want the word 'Zero' in it.
  23. Possibly both, although rear first.
  24. Can anyone recommend a company to make a custom metal name badge for my car? I can find a couple online but I'd prefer a recommendation and a rough idea of cost would be interesting.
  25. nelmo
    Rally Events
    There was a guy who used to do it in his Reliant Robin every year, so we're halfway there, in terms of wheels
