ZeroKnowledge
Everything posted by ZeroKnowledge
  1. renewal for me £125 with FPickles (same as last year) is on fully comp 3000 miles 2L engine clean history & licence tried 2gether £120 with free legal TR Youngs £109 gonna ring FP see they will match youngs
  2. ZeroKnowledge
    Iva Test Results
    looking good did you drive or trailer it ?
  3. ZeroKnowledge
    Type 9
    work mate selling this on gumtree http://www.gumtree.com/p/cars-vans-motorbikes/ford-5-speed-type-9-gearbox-75-ono/1013187733
  4. I will be goin in the tintop if anyone wants a lift over
  5. Workmate has this FS on gumtree http://www.gumtree.com/p/cars-vans-motorbikes/rickman-ranger-kit-car-200-ono/1012861862
  6. i`ll be goin to as many as I can also considering a trackday at Elvington in august. if I can get a shift swap I will be at mouse next week cheers Paul
  7. Hi Andi I had a diesel tino for 10 years, great alround car, take all back seats out (undo 6 clips to remove them) & its like a van
  8. Hi Ozz heres a photo of the bracket on my carbs, its nowt special just strip 2-3mm thick, (sorry its been a while since u asked) my carbs are joined to manifold with silicone pipe, They never came off but the bracket just makes them abit more rigid Cheers Paul HTH
  9. I would say you also need some sort of bracket to stop carbs moving
  10. mine is -magnet on diff/prop flange & sensor fixed to tunnel side works no probs
  11. usually its the Halfords own label stuff thats cheapest, just ask them to scan the items- to check trade price before you buy
  12. I just told them I was buliding a kitcar, smiled/said please alot and got trade card no problem. :)
  13. looking good chris what colour did you go for??
  14. Moral: DON'T trust the DVLA to get things right Very true-check ALL details on V5 when you get it, mine had emissions info for a diesel
  15. I went & talked to local DVLA office as they would be doin build up inspection they were happy for me to make up my own VIN number but you cant use certain numbers/letters (cant remeber what they are though)
  16. before I do a full rolling road session I have done a compression test on the engine.(using sealey VSE300D) haynes manual states it should be 11-13 bar first results on hot engine with all plugs removed showed all cylinders were around 6 bar, then I remembered that the throttle should be wide open. 2nd results were between 15 & 16 bar. as the head has been skimmed would this account for higher than spec pressure??
  17. hi Luke give me a shout if you want to pop over & have a look at my bike carb setup Paul
  18. some info here John http://www.greatnorthflyin.co.uk/ I am away in van this weekend so wont be able to attend Cheers Paul
  19. thanks for the carb tuning link, I`ll have a good read tonight Cheers Paul
  20. results from RR Power run Flywheel 113 BHP (standard is 125) Wheels 91 fuelling was all over the place with rich low range- lean mid range and rich high range, I took my laptop for the megajolt so I could maybe learn abit more about it (I am using a map from another DOHC user). he changed a couple of values on megajolt and immediatley got 3hp more. looks like I need a full RR session to get carbs & megajolt setup. from searching the forums for a RR that knows bike carbs and megajolt looks like its a long trek to torque tune next to GBS unless anybody knows any up north that fit the bill ?? PS.Very scary standing next to it when at full throttle
  21. results from RR Power run Flywheel 113 BHP (standard is 125) Wheels 91 fuelling was all over the place with rich low range- lean mid range and rich high range, I took my laptop for the megajolt so I could maybe learn abit more about it (I am using a map from another DOHC user). he changed a couple of values on megajolt and immediatley got 3hp more. looks like I need a full RR session to get carbs & megajolt setup. from searching the forums for a RR that knows bike carbs and megajolt looks like its a long trek to torque tune next to GBS unless anybody knows any up north that fit the bill ??
  22. Ive had the zero on the road for 2 years & 3000 miles, so thought it was time to find out the HP I was hoping to use the local RRoad (XO tuning, Cramlington) for a power run but they have just had RR removed, but they did recommend Evotune in Durham. spoke to evotune today and they have an open day on Sat 15 Sept. with power runs for £35. the morning is booked up but after dinner is quiet. I will be there at about 1pm . anyone else interested?? Cheers Paul
  23. Hi Luke Have you checked that the fuel tank is vented?
