femster87
1,075 -
11
Everything posted by femster87
lol thanks John, You always come to the rescue. Thanks again femi
Does this foul the upper rail in the zero. Is the reason for fitting the raceline water rail just aesthetic
thanks alot mate, saved me some money.
Is a remote oil filter required for the blacktop zetec to clear the steering shaft.
Sand blasting. find a local company. it saves a looooot of time. Also electrolysis is used but i dont like it personally. and finally the good old wire brush on angle grinder. takes so much time and you might end up looking like an hedgehog.
thats soooo quick. Thanks alot steve
Hey up, Sorry am up with my measurement requests again. I need the measurement for the zero type 9 propshaft. Am having one made.I know GBS stock erm. Just wanted to have the pick-up fitted and the whole thing balanced ( prices are not too far apart). I have attached the measurements required. please please if you have the time. just flange to end of sleeve & flange to gearbox seal thanks alot femi kit_car_single_piece_shaft.pdf
lidl is stocking this next thursday I believe. Only £49 rated up to 250kg. So would even lift the dreaded pinto. Saving you an hernia operation
Welcome mate, This is the mad house. 4 months into my build almost done I reckon lol. ( engine still not in, too many modifications ). But the kit is a joy to put together. its cheaper to get chassis painted but go for the powder coat option. spents years painting lol. And still not the best finish ever. As Nick and John have mentioned feel free to ask any questions. You decided on engine yet? Am yet to see a BEC zero. Common do it do it lol just messing Enjoy it mate femi
here is a picture mate http://s1210.photobucket.com/albums/cc414/femster87/?action=view¤t=Seats.jpg
Question For Zero Owners With Windscreen
femster87 replied to femster87's topic in Fitting & bodywork
thanks alot nick, your a star -
Can someone please measure the length of the bottom end of the windscreen for me please. I have been offered one and wanted to know the if fits my car. I do not have my scuttle yet so cannot infer. Sorry for the hassle. Thanks in advance Regards
I have for sale my acewell 3100 digital speedo. This was bought used off the bay a while ago. As am not planning on using it. I would like to get what i paid back for it. so its up for sale for £45 here are the features Features Multifunctional LCD ATV / Motorcycle computer includes analogue and digital tachometer, speedometer and clock. LCD has 2 digital rows and analogue RPM bar-graphic display with blue LED backlight Odometer and total riding timer cannot be reset and are permanently stored in memory Displays clock when in standby mode Can be easily switched between MPH and KMH Adjustable wheel circumference from 1 to 3999mm Fully waterproof Includes bracket, speed sensor and wiring harness Vibration (8G) and mechanical shock (10G) tested EMI / EMS tested, E-Mark certificate Dimensions: 95.2mm x 72mm x 28.5mm Functions Symbol Specification Bar Graphic Tachometer 11,000 RPM Digital Tachometer and warning RPM 10-19900RPM, 100RPM increment Speedometer KM/H / MPH 2.4-300km/h 187.5mph Trip meter 1 & 2 TRIP 1/2 0.0 - 9999.9 km/miles Odometer ODO 0-99999 km / 0-62490 miles 12 / 24 hour clock 0:00 - 11:59 / 23:59 Average Speed AVG 2.4 - 300km/h (187.5mph) Riding Timer RT 0-99H59:59 Maximum Speed MAX 2.4 - 300km/h (187.5mph) Total Riding Time TT 0-9999H http://www.acewell.co.uk/Acewell%20Speedometers/ACE-3xxx/ACE-3100.htm?action=full&id=2
steve i have got one you can have if you still after one mate
yes Andy, you can use the standard flywheel and clutch with those parts. Graham, i have been informed the tha spoigot bearing at the end of the cranks helps centralise the input shaft and prevents the wear on the end of the crank and input shaft. I would not think it matters too much if you have not fitted it. if the release bearing is ok and everything is centrally located and no movements then it should be ok. i think.
alrite Andy? I am currently doing the same thing (black top). I retained the 2.0 flywheel and clutch assembly (cost reasons). I fitted a spigot bearing into the centre of the flywheel for the type 9 input shaft to rest on. Alsoo i have a ford transit diesel 2.4/2.5 clutch release bearing (cct303). if do use the 1.8 zetec flywheel (weight advantage) you would need a ford capri release bearing (cct133). Also the standard clutch kit for the 1.8 zetec can be used Hope that helps femi
longer one is to the right and shorter to left ( i think) well thats how mine has been done
yeah i have really considered the new fuel thank. I just dont like the idea at all if am honest. I rather have everything together in one thank. I might just tell gbsc to swap it for other items for me. And I would get a seperate tank with integrated swirl pot.
I have for sale my 1.8 pinto. i was gonna use this before i swapped to a zetec. in its standard condition. came out of a tiger. the sump has been shortened (no extra capacity added) but strengthened with 8mm bars welled at bottom to prevent damage, this was all done by previous owner. its just sat in my garage now so please come and take away for £25. also one of the stud bolts on the exhaust side got sheared in the head been drilled out so a bit wider now would need to be rethreaded and bigger bolts used. also I have an exhaust silencer and primary tubes that came of the same engine. no collector. £60 picture here http://s1210.photobucket.com/albums/cc414/femster87/?action=view¤t=DSCF2801.jpg&newest=1 regards femi ps am going up from scunthorpe to luton on saturday so delivery can be arranged if you are along the way(would be early in morning)
thanks guys, also for swirl pot location, does it have to be in the engine bay, can i not put it near the thank?
what fuel pump have people been using and where can i buy one from please.
Hi John, I ordered my premier loom yesterday, so my sierra loom is surplus to requirement. Only problem is that i have started to sort it so most wire wraps removed. so the wires to the relay box and fuse box are in a major mess but everything else is taped into clusters. Also the relays are getting used in the new loom. finally its heavy and would cost a bit to post. Apart from that. you can have it for a £10, just to get some connectors for my new loom. PS. Am surprised you considered the £400 loom. I just could not believe it when I heard it.but i know a lot of work is involved. but thats alot of money for wires. let me know what you want to do. regards femi
