Stewart
Everything posted by Stewart
  1. Well done Nick glad to hear the good news,also that you are staying on here as your input usually consists of very good advice with the occasional hint of sarcasm.The guy who bought it wasnt Richard Cranium then??
  2. Unfortunately not a twin choke weber not a single cable and not on a pinto engine and not close enough to see the connections,but thanks for trying anyway as it appears nobody else has any spares or photo`s.
  3. Has nobody got any photo`s that show this linkage???
  4. Has anyone got any photo`s showing the throttle linkage between the pedal and 32/36 twin choke webers on a pinto engine or better still has anyone got such a linkage to sell.
  5. Stewart
    Zero Alternator
    depends on which engine you are fitting
  6. Allso on ebay 140841427331
  7. Went yesterday,was dissapointed at the ammountof exhibitors but thought being able to watch the racing was excellent,had a good look around the RHOCAR vehicles was disapointed that the members I saw were not in a very sociable mood and not interested in anything only chatting among themselves.I did speak to the only person I recognised who seemed totally uninterested. POSTED SUNDAY PM
  8. Stewart
    Wiring Loom
    Ring GBS ask for Simon he has a spread sheet of all the wiring looms and is a extremely helpfull man.
  9. never worry about things you can`t do anything about
  10. Thanks again for all your birthday wishes
  11. Has anybody purchased or made one recently to fit a Zero,the guy on fleabay makes them for 50£ but you have to find a way of rounding the ends for IVA.
  12. Thanks for all the help problem solved faulty rear fog light switch.
  13. Well done the north east area coming together to offer help and advice to a new member,lets hope it rubs off into other area`s.
  14. Tried switching headlights to main beam before switching on and they worked OK,removed dipped beam relay and switched lights on fuse blew.?What size fuse should the dipped headlights require,the digital dashboard and horn are also on the same fuse.
  15. Yes they worked OK when first wired,using sierra column switches from 1992 sierra,using relays,think seperate fuse for main and dipped,the fuse is also for the horn and digital dash they all work its only when dipped headlights switched on does fuse blow.
  16. original fuse was 15amp tried 20amp and even 30amp all blew as soon as the switch was activated,seem to recall someone having this problem a long time ago and the result was switch failure does anybody recall or had similar problem
  17. Just came to do a final lighting check as soon as headlights switched on fuse blows,tried all other cobinations on that fuse and is definately headlights,disconnected each headlight in turn and fuse still blows,stuck for idea`s can anybody help??
  18. Stewart
    British Grand Prix
    Take a portable radio then you can tune into radio silverstone and get a running comentary on whats happening in the area`s you cant see
  19. My Susuki Vitara has wipers that park on the passenger side.
  20. Looked through the NW hoodies web site could not see the mod for gear lever
