ibrooks
Everything posted by ibrooks
  1. After the first fit with self tappers I went on to replace them with M4 bolts. I then dismantled it again (gets soul destroying the number of times you have to do that doesn't it) painted it and reassembled with stainless bolts (dome headed ones of course to avaoid the dreaded sharp edges). Iain
  2. The one you've put most effort into. If you're looking at a pre-built Hood then look for one with "proper" wishbones as these will be easiest to adjust with bolt on shocks and springs to get the settings you're after. This would discount an Exmo (unless it's been modified) and an early 2B (same caveat). The Sierra based Hoods also have IRS which is going to be better (again when setup properly) so maybe limit yourself to them. The engine is up to you and what you're willing to spend or do yourself. If you look at a Pinto then a later engine will run unleaded and you'll have to use your judgement on what the seller tells you about what's been done with it. Get them to drive you in it or let you drive it and see what it performs/feels like. Again every kit-car is different so apart from vast generalisations it's difficult to tell you to look for. It also depends on what you're looking for. If you want creature comforts then they all add weight and will make the car less performance driven. If you want a track-day weapon then you'll want to remove things like a stereo, carpets and boot linings but it'll be less practical. After that it's aesthetics I like the looks of swept wings but they are horrendous from an aerodynamic point of view. Stainless or painted etc etc etc. Iain
  3. ibrooks
    Fuel Supply
    You need a single pipe from the tank to the pump. From the pump you go to a pressure regulator. This sends one pipe to the carb and another back to the tank. The fuel being sent back to the tank is the excess that the pump shifts as it is capable of moving more than the engine needs. The reason that the Sierra setup has it going back to the tank is that the "three way thingy" is also a vapour separator and so there may be gas in that line. If you ditch the Sierra regulator and get a filter king one it is a diaphragm type and just closes off when the pressure is too high so you don't need a return line. It's also available with a built in filter which sorts that job at the same time and it's adjustable. Vapour separation isn't necessary with shorter straight lines as any bubbles that form are relatively quickly forced through the system and cause no problems. In the Sierra where the pipes run up and down there are areas where bubbles can collect and then all come through at once and possibly cause the engine to stutter. If you are determined to use the Sierra regulator run the pipe with a rise at each end and flat in between and just T the return into the line that supplies the pump at the front of the car. Iain
  4. I've sent pics to some people who specifically asked but here's one for the masses. This is the Hood I bought with my 2B but since I'm using the S7 till the 2B is on the road I snaffled it and will get another for the 2B. It's a pretty good fit and keeps me dry in the rain.
  5. Depends on your criteria. If it's looks then all three. If it's track day performance then none of them. If it's "bang for buck" then Caterhams and Westfields can't even come close to matching any Hood. Any Robin Hood is a Lotus Seven inspired sportscar (LSIS for short) and so looks like a Lotus Seven and so similar to the others. Westfields are also LSIS's and the Caterham is more of an evolution of the Lotus Seven (that last may cause an eyebrow or two to raise but...). The S7 and Exmo are built differently and so they tend to be heavier (monocoque rather than a spaceframe). They are also designed to use the Ford Pinto engine which tends to be heavier and less powerful than the engines used by the other two. The 2B is a spaceframe but there is more steel in the panels than fibreglass and so again they tend to be heavier. Again most use the Pinto but some are now using the DOHC about which I know nothing (but I suspect it's still heavier and less powerful than a Vauxhall XE or K-Series which Caterham and Vauxhall tend to use). So out of the box expect the Hood to be slower and not to handle as well (but it'll cost a fraction of the money). If you're prepared to play and get your hands dirty then the Hood can be made to match the others in pretty much all aspects apart from weight (and your grand total should still be significantly lower). Personally I like the combination of a bit extra weight and the Pinto. The extra weight means the car soaks up lumps and bumps better and tends to be a more comfortable road car. I'm also a fan of the Pinto as it's bomb proof and very torquey so it makes for a much more relaxed drive at normal speeds (up to 100). Basically any Kit-Car is what you make of it (or whoever built it made of it). The Robin Hood will take more effort to get to the same level but it can be done and it'll cost you less. The Hood is a better road vehicle but won't compete on a track. Don't be fooled into thinking from this that a Hood is slow and doesn't handle. A basic Hood will embarras the most modified of hot hatches and you'll have to spend telephone numbers with the big boys like Porsche, Ford or BMW to match it for performance on or off a track. Sorry it's long winded but it's a big question. Iain
  6. ibrooks
    Insurance
  7. ibrooks
    Insurance
    I also do this as a matter of course nowadays but it irritates me that I have to. Given that we are required by law to have insurance I'd like them to be required by law to give me their best price every time rather than just what they think they can get away with - but I suppose that's retail. Unfortunately they all share data nowadays so how do we know they aren't actually price-fixing? The system stinks and the only reason I bother is that I'm legally required to so the best price I can get for number one is what I go for. If the government (and that's any government) had an ounce of common sense they would see that if they make it easy for someone to comply with a law they probably will. If insurance was a reasonable price people would be less likely to drive without. If taxation on fuel was sensible people wouldn't risk running on red diesel if public transport wasn't a joke more people would use it etc. etc. etc. rant rant rant. Sorry - just read the stuff about the guy who was fined for warning people about a tax camera so I'm in a particularly anti-authority mood. Who'll vote for me? Iain
  8. I have fitted a 2B hood to my Cortina based s7 and it works just fine. The only problem was that the frames were too wide and too long. This means I had to cut a lump out of the middle of them and they are mounted further forward than they really should be so when they fold down they don't lie along the top of the rear panel. They actually sit on the roll-over bar supports - if this is the price I must pay to stay dry then it's well worth it. If anyone wants pics let me know (or give me a shout and call round to look at it). Iain
  9. ibrooks
    Hard Top
    Yes guys I have an alligator bonnet. I haven't done it quite the way RHE suggested but it's similar and so the screen moves when the bonnet is opened. I quite like the system (modified like mine) as it makes life quite a bit easier in and around the engine bay so I don't really want to go the fixed scuttle route. Unfortunately it looks like I'll have to do without then as a removeable centre section of some sort would be the only real solution if I want to keep the alligator. Iain
  10. ibrooks
    Hard Top
    and a nother!
  11. ibrooks
    Hard Top
    Looks good and I would be interested in one for my 2B if it would allow me to use it as everyday transport. Just a thought on the doors have you seen the ones that were used on the Carcraft Cyclone as they would make getting in and out much easier and could probably be stored in the car when removed. It was a Sevenesque motor with a fixed front and rear screen. Instead of a fixed roof there was a fixed central bar (MR2 T-Bar style) which the doors hinged from. The doors also hinged at the corner where their "roof" portion met the door proper. When they opened they went straight up and folded in half to create a flattish panel sticking straight up in the middle. I've just re-read this and am hoping like the proverbial that someone will provide a picture coz I'm now confused and I've seen em . There was a Cyclone in the club area at Donnington - whose was it (some relative of Mr Sheens from memory?) does someone have a pic?. The reason behind this is also that maybe the central bar could be made removeable because otherwise I wouldn't be able to open the bonnet with the roof on. Iain Found some!
  12. ibrooks
    Shell Optimax 98 Ron
    BMW's had a problem with fuels that have too much sulphur in them. BMW came up with a "wonderful" process whereby they used a chemical process to harden the Aluminium of the cylinder bores and therefore didn't put steel liners in their engines. This made for lighter engines but... If there is too much sulphur in the fuel and you draw water into the engine (damp air like we get on the odd occasion in this country) the sulphur becomes sulphuric acid. Now this stuff is corrosive to any metal but it loves reactive metals like Aluminium and since chemical reactions generally happen faster when they are warm (now where inside a petrol engine could we possibly get some heat from) the aluminium of the bores was simply eaten away. BMW now line most of their engines like everyone else but those with the engines that were made without are warned - don't use cheap fuel. High milers who managed to provoke the problem into occuring during the warranty period were laughing as BMW changed the engines for them. Those who do less mileage get stung as the problem will take four or five years to manifest itself. But still people buy BMW's Iain
  13. ibrooks
    Robin Hood As A Donor?
    The DVLA regs that cover this are exactly the same as those of us using a Sierra as a donor. BUT since the car you're wanting to build is similar to your donor you have a different option. Basically the original I.D. of a donor vehicle can be retained as long as enough parts are used from the donor (under the old scoring system that used to be used for kit cars to be registered under the donors reg number) and - from the DVLA "The body type is not changed and the appearance is not significantly altered." Outside of this you have to have an SVA test and it's this last bit that pushes the rest of us down that route. So long as you use enough of the Hood then my reading says that any LSIS can be built from the bits and still be considered the same car. You should be able to get the V5's make and model changed without anything other than a built-up vehicle inspection and it's attached declaration from you stating where all the parts came from. Of course as we've all seen each DVLA/DOT/VOSA jobsworth involved will have his own "special" interpretation of all that so you may have trouble getting the V5 changed to reflect the new model. If you didn't bother (my 2B was very nearly an S7). From a day to day point-of-view as long as the insurance company is informed of exactly what they are insuring then the only problem would be if an MOT tester refused to test the vehicle because his info says Robin Hood and what he has in front of him isn't a Robin Hood - does what you're planning look like the picture on your membership card? Then what does the MOT tester know differently? As an aside. A friend of mine once had a Discovery that was described on the V5 as a Montego because it was a pre-production testing vehicle. He had a raft of Land-Rover headed paperwork that he had to take to the garage to get the guy to write Montego on the MOT certificate at MOT time. Apparently there were a bunch of these that were used as final testing mules (in various parts of the world like the Arctic and the Sahara). Iain
  14. You'd be twice as jealous if I told you what I paid for the S7. It wasn't a drive home vehicle as a result but it didn't take too long to get it through an MOT. It's a fairly basic motor and there are several jobs I'd do to make it nicer and personalise it if I was going to keep it but that would just take time away from finishing the 2B. Iain
  15. I brought driving pleasure closer by buying an S7 I'm still working on the 2B so I'll sell the S7 once it's on the road but not before (wouldn't be without one now). Iain
  16. Well as far as 2B's go I've got you all beat - mine's out of the first batch August 99. Is that something to be proud of or not? At least it means I got mine cheaper than the rest of you. Anyone else who was there that day who still isn't on the road? Iain
  17. ibrooks
    Arc Welder
    Or I have an Arc welder you can borrow and I have also just replaced my MIG welder so the old one isn't doing anything (it works fine but if you're doing anything big it tends to hit the thermal cut-out fairly quickly so you have to do somethng else for half-an-hour while it cools down again). Iain
  18. Well guys glad you've all enjoyed it - come on Jim what did you get? - and what about mad-max? Brian did most of the legwork as a thank-you for the help he's had from the guys who've turned up at the classes where he's building a SubK. Jim then did the organising with Adrian. Hopefully there will be futher sessions and I'll get one or other of my Hoods down there. Iain
  19. Thats a nasty cough Mat - you picked up a virus from somewhere?
  20. Hi Bob, Not if it's standard. The 4x4 is the car you want for an LSD. Iain
  21. ibrooks
    Axle And Design Weights
    Now I'm beginning to get worried here. I've recently sent the form off for my 2B (surely one of the last of the first batch that's not on the road yet). I used the figures you guys are quoting for axle one and two but I don't remember filling in a gross - please tell me I haven't missed a box on the form . Oh well we can but wait and see. Iain
  22. He's such a nice boy when he thinks before he speaks isn't he You'll notice he's studiously avoided telling us where he is. Maybe he's afraid we'll come looking. Seriously Steve let us know and you can probably have a look at a car in the flesh anytime rather than having to wait for a show - and probably a ride and maybe even a little drive. If you're anywhere near me (Darwen) give me a PM and you can come and have a look at my Hoods (one of which is for sale - but don't tell anyone until the other one is on the road ). I'll drool over your Mini and you can also laugh at mine (two 1976 Clubmen in sore need of my attention). Iain
  23. Ant, I got a kit from Frost (www.frost.co.uk) which is basically a pair of mole-grips with various attachments to crimp all sorts of these things. It also comes with many different types of fastener (including some poppers very similar to what came with my hood). If you want to make a bit of a trip (Darwen) you could borrow it as it is a bit expensive to buy just for the number of poppers around the hood (I also had a 40ft narrowboat to make a couple of covers for so it paid for itself a bit quicker). I know some have had good results with the posi method but I wouldn't recommend it as the resulting rivet in the popper isn't as strong and i've seen many of these where a couple of poppers are left on the car when the top is removed. Just a comment - I'm sure it's worked fine for some people. Iain
  24. Joel is right. The Puregrot centre spigot is bigger than the Ford one. You can buy spacer rings to fill the gap (or get them made up). Many of the aftermarket wheels are made with the larger centre hole regardless and the rings are provided with the wheels. I have a set of Alessio wheels that came like this. Iain
  25. Jase, Ask for wheels for a Capri, Cortina or MK1 or 2 Escort. They have the normal Ford four stud PCD and the same offset as the Pug (which just happens to be the offset used on most rear wheel drive Fords except the Sierra). If you get Pug wheels you will need special wheelnuts as their taper is different to Ford. Capri/Cortina/Escort wheels will fit straight on with your existing nuts. Puregrot wheels are good if they come cheap (free) and you only have to sort a set of wheelnuts. If you're buying new anyway then get the Ford fitting and save yourself the messing around. Happy Birthday Iain
