Bob Tucker
  1. Bob Tucker
    Weber 45
    Hiya, My 2 pennorth..... I've had both DGAS & twin 40s fitted to the engine. The DGAS (with two off 27mm chokes) runs as sweet as a nut, hard initial acceleration, but runs out of puff above 5k. 30-35 genuine mpg. The 40s (with 4 off 36mm chokes) pull far harder from 1200 rpm, flat to the floor, no hesitation, & scream round to 6500 with more to come but at a risk to the engine (standard bottom end). I've been out today, hammering it in low gears. I started with a full tank, & refilled it after 52 miles. It took 14 litres. That's about 16mpg. Best I've got on a run was 23 mpg. The family accountant says the DGAS is going to have to go back on soon......but I know I'll miss the 40s, the induction roar, the smell of petrol inside the car when I accelerate, the petrol smell in the garage, the rapidly shrinking hot hatches in the rear mirror... Honest dear, I'll change it next week....
  2. Andy, can you reconfirm your carb type? The DGAS was never fitted to the Pinto by Ford. The standard (early) fitment was a DGAV with sequential choke opening. The DGAS was fitted to the V6s and both chokes open simultaneously. Jet sizes are very different from the DGAV. Also check that there is no leak in your pipe(s) to the brake servo. If need be disconnect it from the manfold, plug the manifold hole & try again....BEWARE the brake pedal is much harder without the servo. Good luck, Bob.
  3. Hi Nigel, If youve still got the Ford cam wheel, mark a line on the vernier where the woodruff key fits. Align the Ford wheel so the woodruff slots line up, then transfer a mark onto the vernier where the pointer of the Ford item comes. Then follow the Haynes manual. After that you really need the dial guage & protractor for fine adjustment of the hotter cam. Cheers, Bob.
  4. Bob Tucker
    Handbrake
    Yup, tunnel top is the way to go. I replaced the half moon with a smaller pulley narrower than the tunnel top. Then I added a S/S sheet extension from the tunnel sides, up over the handbrake, nice rounded top, covered in carpet looks pretty neat. Cheers Bob.
  5. Bob Tucker
    Starter Motor
    Also check that you have a GOOD earth from the chassis to the engine.
  6. Bob Tucker
    Help
    Hi Delta 2, Tiger have a build factory in Plumstead, South London. I'm sure they'd show you around if you ask nicely.
  7. Bob Tucker
    Head Gasket?
    Robbie, Theres a water pipe that feeds from the top of the water pump. It goes into the heater (if fitted) then into the carb autochoke(if fitted) then back into the manifold, and into the head via a rectangular port smack bang in the centre of the head between the 4 inlet ports. If youve blocked off the water pump thermostat bypass & the rectangular hole into the head, that will account for it overheating, & if your port gaskets are faulty, then it will let the water back out of the trumpets. My Weber manifold has a short tube screwed into the flange, where the pipe goes. Take a look at some of the engine build pictures for more details. HTH Bob
  8. Hi Kevin, the diff you need for accelaration is the 3.92. For some odd reason t was fitted to some 2.0 injection models. BUT if you plan on long distance motorway trips it gets pretty wearing. at 70 MPH with a 5 speed box its doing abut 3200 revs. The 3.62 at 70 is doing aout 2700. Check the VIN plate or the tag on one of the diff bolts to confirm the ratio. Theres a series of codes which was on one of the sites (cant remember where) Most other models of 1,8 & 2 litre had the 3.62 diff. I dont know about the 1.6. HTH Bob.
  9. Well done John.... Its a great feeling driving it home after an SVA pass isn't it? Hope to meet up with you again, & the car, at some of the shows.. Donington perhaps? Bob Tucker
  10. Bob Tucker
    Rear Springs
    Hi Ian, No. Both ends of the spring have stayed put over 2000 miles. I kept the rubber spring caps which seat in the McP struts. You could drill a hole in the cup & A frame & fit a tie wrap or jubilee clip to keep the spring away from the halfshaft.
  11. Theres also (there should be!) a non return valve in the pipe.....
  12. Bob Tucker
    Rear Springs
    Hi Ian, I had this problem on one side with standard Sierra springs & shockers. The solution (Honestly!) was to whack the spring away from the drive shaft with a big mallet. Theres some play in the McP cup at the top & lots in the A frame, theres now about 3/4 inch gap. . I painted the drive shaft to check, & no more scuff marks. Cheers, Bob the Basher
  13. Reminds me of a time long past when I ran a Lambretta (I also ran several 650 BSAs) so dont call me a mod... The Lambretta was stripped of all bodywork & I took the girlfriend to see her brother, a trip of about 30 miles. After about 2 miles we spluttered to a halt, got off, looked around, found nothing, but it started again after a bit of persuasion. Another few miles, same again, then repeated every few miles till we arrived an hour late. When we went indoors, the girlfriend shrieked....one leg of her flared trousers had a dozen dirty, oily, petrol smelling circles....the leg next to the open carb intake, which had repeatedly sucked her trousers in & choked the engine. She got her own back by marrying me....
  14. There have been cases of cloning, especially with the London congestion charging. Spot a similar car, type & colour, get a set of plates made up & they get the ticket, not you. That's why its such a pain getting new plates made up now, but all in a good cause.
  15. Bob Tucker
    Loophole
    When SVA first came out, the price of old Duttons shot through the roof. Anyone guess why? Yep, already registered Duttons suddenly began to look like other more recent 7s. A quick notification of engine change to DVLA, put the Dutton VIN and number plate on your new car & who's any the wiser when you scrap the Dutton & sell the parts on?. Definitely illegal tho....
  16. Bob Tucker
    Bromley
    Hi Graham, I do indeed live near Bromley & I avoid it whenever possible because of traffic problems any day of the week. But I have got hold of an exhibitors ticket and intend to get there early on Sunday weather permitting. The only advice I can offer is that there is a back entrance to the park in Hayes Lane which is less well known, but you are still stuck with J4 M25 then A21 to get anywhere near Bromley anyway. You can get closer coming via Biggin Hill, (M25 J6 then A25) but its pretty roundabout & you'd have to work out your own route. Hope to see some of you there. Cheers, Bob. The following may help a bit.... http://www.multimap.com/map/browse.cgi?cli...=true&advanced=
  17. Hi Jim, The side screens can just be "wangled" under the roll bar, and fit between the rear cross braces. The bottom sits on the boot lid & the top sits on the headrests. They cant get out of the sides, or the back. You can use bungees to stop them flapping. I've just done about 800 miles to LeMans, Loire valley & an airshow in Paris over the last 2 weeks. They stayed in place no problem at some silly speeds. Bob (now pronounced "Berb")
  18. Bob Tucker
    Build Tips
    Hi Guys, I used two small but very bright LEDs which fit into the steering column shroud. They are run from the dash wiring to the instrument pod indicator light. Best of all, the standard wiring seems to switch +ve & -ve depending on right or left, & the LEDs only work one way round. So I have both a left & right indicator light. Cheers Bob, (non-Leccy)
  19. Bob Tucker
    Dash Lower Edge
    I got a length of 19.2 MM water pipe from Halfords. It comes in rolls so its already curved to roughly dash shape. Slit it as required, put double sided sticky tape on the dashboard edge & push it on. If necessary put edge trim on the dash first to stick the tape to. I passed SVA at Gillingham that way. Bob
  20. Just to add to Mick's reply, Bob (the other one) can also polish them for you and drill the two fixing holes...dunno the cost. But you can use 800 then 1000 or 1200 wet & dry lubricated with Brasso or similar followed by Solvol Autosol to get a mirror finish. Or buy a polishing kit at the shows... Theres a piccy of my pillars on the Yahoo Photos site as follows.... http://photos.groups.yahoo.com/group/robin...rc=gr%26.view=t Cheers, Bob T.
  21. Bob Tucker
    Options Avaliable?
    You need a Type 9 gearbox, where reverse is left & forward. I think some Grannys had the MT 75 box, where reverse is right & back. They are physically bigger, can be fitted but require some major mods. Stick with a Type 9 for (relative!!) simplicity. Bob.
  22. Bob Tucker
    Exhaust Mount
    I didnt fancy drilling holes into the side panels, so I made up an L shaped bracket which goes under the car & bolts to the square chassis plate, then goes vertical about 1 inch away from the body side, then two Mini bobbins to the silencer bracket. Bob
  23. Bob Tucker
    Engine Blips
    Hi John, to add a few things to our previous emails re DGAS setups.... I have a single fuel pipe (no return) and use a Filter King combined filter & pressure regulator. Bob.
  24. The bigger motor factors carry them....I paid £3 for one recently.
  25. Also worth checking out the yellow cam gear on the clutch pedal. If youve lost a tooth you wont be getting full travel. Bob
