Hi and thanks in advance for any help, I'll most probably ask all the usual questions.
Crate blacktop going in a cortina based S7 running DANST ITB's OMEX ECU and custom loom, bolting onto a type 9 box.
So for the questions!!
1. What are the chances of me fitting the engine and keeping the servo? Any tips? Any way I can make this work?
2. Exhaust manifold, I've already had some advice on an option. I'm keen to have the pipe exit the side. I spoke to Richard from GBS and he advised one without flanges but I didn't fully understand what he meant, minus flange so I can cut the pipes down for the correct width?
3. Kit spares engine mount suitable for the s7?
4. What psi fuel pump will I need? I already have a return pipe fitted. (GSXR1000 ITB's)
Thanks!
Edited by flameredturbo
Guest kevin booth
If it was me i would tap into all four inlet pipes then tee together, Then take a main pipe to the servo, this would stop one cylinder going lean. But in my opinion you do not need a servo if you get your brake cylinder size and fulcrum point correct.
I would think space would be your biggest problem you may have to change the pedal box to an inboard master cylinder and do away with the servo.
I picked up a westfeild zetec manifold off ebay if I could post a picture but cant cos it wold be pornographic its that gorgeous also picked up pipe and repackable silencer in chrome for 100
cant beat a bit of car porn especially shiney bits
The inlet is being made with a servo pipe in the hope I can fit the lump in with the servo in situ, any pictures of anyone that's managed this. I've read a horror story or two about pedal boxes!
going to get the angle grinder on the sump today to make way for starter motor
Is hacking away at the sump the only option? Is your engine bolting onto a type9?
Thanks for all replies btw.
That's all good then, sounded worse than It is. What option did you go for with clutch and flywheel? I'm thinking of just keeping the standard set up and getting a spigot bearing, did you need a clutch arm pin too?
Just been doing some reading up and my plans to simply bolt all this to my existing box might be buggered, I have a 4 speed quaife rocket clubman........ Just read its a 5 speed box I need as the castings are different?? Its a type E that I infact have after reading up, PLEASE advise.
http://quaife.co.uk/shop/products/qbe6z-0
I am trying to fit a 1.8 zetec flywheel to a pinto clutch in a type nine box don't know why a four speed wont fit I would have thought if you use a four speed friction plate change flywheel and pressure plate as the four speed fits pinto and five speed why would casing be different
I think the bellhousing is the same (I wrongly assumed it might be different and after seeing a post saying you can't use a 4 speed). Dead easy to swap if not, as long as the input shaft is infact 1"x23 like I've read it should be then I'll be fine. The only thing I could do with confirming now is if the Type E sits any further forward or backward than the type 9? And just for any reassurance that it will all work!!
