Sebring Project
femster87
Hi, I've been looking again at your photo of the front end set up.
I'm a little confused with the front shocker lay out with the Armstrong.
I cannot see a link arm that will allow the shocks arm to move through the radial path they require without link arms.
Am I missing something?
Edited by 2b cruising
Hi again. Yes I get the swivel part of it. What I don't get is you shock is solid mounted, you actuator arm is fixed to the top of your upright.
As your suspension goes up and down, how do you maintain a constant camber with the arm moving through a radial plane.
  • 1 month later...
Well, there has been a lot of work going on quietly on the car but I have been too busy to document this. I will take some pictures later. The car has just been collected for paint. It will be back before xmas
Edited by femster
  • Like 2
Update from painters
Bonnett is not wavy just the dust on camera.
I have the doors to finish and drop off. Also i need to chose the colour. blue or new range rover evoque cherry red. Suggestions welcomed
Edited by femster
Your choice is the one that counts.
Mine would be full gloss none metallic dark blue with many coats of clear to get the rich deep finish.
I'm sure whatever you pick it will be terrific.
