Led Lights
tractor
leds are polarity sensitive..assuming they can be fitted the wrong way ie 501 bulbs.
if not remove them one by one and test them with 12v . also test the relay.
if it worked before the bulb and relay away its one of those items.
Check the LED's work when connected direct to 12 volt battery -- polarity is VERY important -- so try both ways if no joy on first connection. Next try with only one or two LEDs in your indicator wiring, the circuit MAY still need some resistance. If part working with LEDs but not all ,then flasher relay is not up to running just LEDs.
I wish I could type, not faster; just type would be good.
Edited by florin metal works
