I hope you aren't planning on using the original rubber coupling as the youngest it will be is around 24years old. Can you not get a proper U joint to work as the rubber ones are more likely to go pop.
Kerry needs the rubber doughnut to dampen the vibration, it's what's used on the Omega box. He wants the bits that the doughnut bolts to so they can be built in to a new props shaft. I'm sure he'll stretch to a new doughnut.
I have a UJ propshaft and intended to make a new one using a rubber doughnut and damper. It would have to be modified to fit Vauxhall set up
