Ok so need to remove my wheels and have this locking device, where can I get the tool to unscrew these fittings.
You could try Wolfrace Wheels or one of their dealers. Send a picture of your wheel.
Wolfrace Wheels (UK) limited, 6A The Street Industrial
           Estate, Maldon, Essex,
           CM9 4XB
Company Reg. 2406254, VAT No. GB570445054
wolfrace.co.uk – New Shop
sales@wolfrace.co.uk
0845 330 9896
I reckon you may struggle.
Ask whoever you bought the car from, or try Wolfrace UK direct and send them that picture.
insert two flat blade screwdrivers and then use a bar between the 2 screwdrivers to undo the bolt
In my dealings with security spline bolts/set screw on power tools ( many years ago now ) I found that the central pip was quite brittle & generally snapped off with just a tap from a parallel punch & hammer combo.
Then apply the correct size of splined bit/driver.
Edited by fry61
Additional information
bit of the old WD40 if you have to get it off without the correct tool, just to make sure it has the best chance of getting free without too much force
