Hi all
Is this coil suitable for a 2liter pinto?
https://simonbbc.com/Viper-Dry-Ignition-Coil-Sports-Lucas-DLB105-BLACK
I'm not getting a spark and since I don't know the age or condition of the coil, thought I would get a new one.
While I'm at it I'm going to change the leads as well. https://simonbbc.com/Ford-Pinto-OHC-HT-Leads-8mm-Double-Silicone#product-reviews
 Are these suitable? Thanks.
I have read a lot about recent accuspark distributors chewing up the aux shaft and ruining engines. I think it has only started happening in the last few years. Mine is 6 years old and fine. If you look at kit car Facebook groups there are a lot of very unhappy people so I would be careful.
  • Thanks 1
Could this be part of my no spark problem?
The wiring going into is a bit of a mess, what does it do?
Thanks for any help.
Been doing some reading, if I were to buy the kit from the eBay link, could I  get rid of the black box?. I'd then have a full new ignition system and hopefully a more reliable setup.
So, I went ahead and bought the kit from the eBay link above. New dizzy, coil, leads and plugs. Fitted it yesterday, cut all the untidy wiring for the motorcraft box out, Much neater now. Fired straight up, hopefully more reliable now :).
  • 4 months later...
Hi
what ohm coil did you have with the original ford distributor set up
 cheers Darren
On 11/8/2022 at 5:30 PM, Darren Knowles said:
Hi
 cheers Darren
Sorry I don't know. But 5 months after putting that kit on, I've had no problems since.
All sorted now new coil on tonight 😄
