2,006 -
60
Received mine now. First attempt took a fair time, but now I have used it half a dozen times it has become very easy and I do the check in just a couple of minutes. Love it The first reading I got was 20' toe out, and then after moving the car so the wheel turned 180º I got a reading of 10' toe in. So the average was 5' toe out. I did wonder about tweaking it to give a small toe-in, but I couldn't shift the lock nuts on the track arm. Are they opposite threads, or they both normal right hand threads? It does give me a slight problem, I have suffered from excessive wear on the outside of both tyres and had assumed it was the tracking so could easily fix it. Having got those readings it obviously isn't the source of the problem. So googling it tells me the cause is more likely to be wrong camber. So my latest theory is that winding up the front suspension springs to give me more ground clearance under the sump (Superspec owners will now this is a big problem on the car) has caused the wheels to tilt outwards at the top, putting pressure on the outside of the tread and causing the wear ? Anyone any thoughts on that ?
Once again we have been invited to display our cars at the Corby Glen (NG33 4NS) Sheep Fair (https://www.sheepfair.co.uk/) on 3rd October. This is a traditional small village fete with all the usual stalls, entertainment, food and drink, dog show, craft shows, car display..... and this is the 783rd one so they must be doing something right. Unlike other shows the organisers are very relaxed about the car display and although the Fair is open from 10:00-16:00 they are happy for us to arrive whenever we like and leave whenever we like. I normally park up about 09:30 and reserve some spaces (I live only 1 mile away so it isn't difficult). For those regular attendees it's the same as every year, parking by the war memorial. If anyone who hasn't been before would like to come this year just message me and I will send full details.
Hi Tim, nice to see another Superspec owner joining us. That is very useful information, but it doesn’t appear to include a sender for the fuel gauge ?
Thanks for that, I hereby eat my words (although only if he didn't clip the release bearing into the release arm) But as you say, I will not replace it until something else forces me to drop the engine/gearbox. It's been rattling for 25K miles and doesn't seem to be getting worse.
I've seen the pictures, it would need a miracle to recondition that plate. Dean: The code I passed you before (Exedy MZK2100) is the one that Chris used to replace his clutch plate. Have you tried that ? Euro Car Parts carry it, you should get a discount with the Club membership.
Looking at the pictures he/her has a huge job on his/her hands. I hope they know there is 16 years of knowledge on this forum and lots of people keen to help
Yes, I have brochure which has the lightweight, the 2B Plus and the Superspec as the product lineup.
OK, that theory has been advanced before. I am still a bit sceptical as if that was the case I would expect the rattle to be there all the time, whereas we know it disappears the moment you press down on the clutch pedal and force the release bearing against the pressure plate. Hence my theory that it is related to the release bearing. Unfortunately if your mechanic fixes the bush and clips the bearing into the release arm we will never know which of the two caused the rattle But regardless, it’s good news for you as you will have the quietest Superspec on the road I gather you posted a picture of the broken clutch on another site, can you post it on here ? Or PM me a copy ? Cheers Al
Wow, I wonder what caused that. Was it just the clutch plate, or the pressure plate, or both ? Good news that a new clutch should fix it. I don't fully understand his comment about the MT75 needle roller, I have never seen anything like that on an MT75 and it doesn't match up with anything else that has been reported. Maybe he is talking about the bearing that was originally fitted to the gearbox input shaft to match the hole in the output shaft of the Granada engine. We know that didn't fit the Rover engine, which is why RHE machined the phosphor bronze (I think) bush as a replacement. But even though we know the tolerances were a bit iffy I don't understand why a slightly loose fit of the gearbox input shaft into a phosphor bronze bush would create a metallic rattle. I would have thought it would just wear away the bush. But I am prepared to eat my words if his fix works. Is he using the old home made release bearing or a proper new MT75 one? And could you ask him if the release bearing should actually be clipped into the release arm ? Fascinating stuff, keep the information coming, it's incredibly useful for other Superspec owners.
I wish they would list them so we could buy what we think we might need. At the moment it’s guesswork.
I've just ordered one. Cheaper than 2 new front tyres And yes, to adjust camber you have to break the top ball joint.
Looks good, but I did note this on one of the sites: Please note: Trackace requires a minimum of 100mm under vehicle ground clearance so for low vehicles it may be necessary to raise the vehicle by placing suitable blocks under the wheels. Is that a problem ?
I haven't heard of any Superspec not fitted with the MT75 (LHD Granada model). Was the gearbox actually different or was it the release arm ? And I don't think the turbo aspect makes it any different.
OK, it seems Chris simply handed in the original clutch plate and pressure plate and that is what he was given in return. So there is no explanation as to why a different clutch plate was used. Sorry, not much help.
Stoneleigh - National Kit Car Show 28/29th August 2021
alanrichey replied to Danielle's topic in Events
OK, ignore previous post. I just did a side-by-side comparison of the site map and the (old) Google Earth shot. They have certainly lost a lot of room with HS2, it's going to be quite cosy if a lot of people turn up. In previous years I have never strayed up to the band stand area so that will be new. I see the kit car entrance is labelled 'Main Gate' (as against 'Main Public Gate'). But in previous years the road has been closed in front of Exhibition Hall so getting to the Band Stand area could be a bit of a challenge. Looks like take second right just before the Westfield drift then first left and then right at the T-junction. I think I will follow someone else -
Although I have been there a few times I am having trouble matching the site map to my memories of the layout. Has it changed completely because of HS2 ? And there is no sign of a kit car entrance, which we always had in the past. And I don't remember a band stand. So very confused -
I’m afraid I don’t know, I am just passing on information I was given by Chris. However the clutch plate and release bearing are not connected in any way so I don’t see why not. I’ll ask him why he went with separate items.
Got my confirmation this morning. I see they have moved our Club stand back to our usual place just by the entrance. So it's going to be a busy weekend, Stoneleigh on Saturday then Stamford on Sunday . I will aim to get there between 09:00 and 09:30. Hope we have a decent turnout (and decent weather)
That was what made me wonder if the clutch cable had seized. Although mine have never seized I have had one get so stiff it was almost impossible to move. Hence my suggestion you see if the release arm still had movement in it. Although I accept that if the release bearing has jammed somehow that the release arm would still have movement. Just making sure you eliminate the 'simple' answers before you make the big step of dropping the gearbox. Also, you should be aware that I don't know anyone who has managed to release the gearbox without dropping the engine as well. I suspect that after removing the prop shaft and the bolts holding the gearbox to the mounting plate you won't be able to move the gearbox back far enough to get it out. I await your attempt with great interest, as if it works that makes life much simpler As to the rattle, we still don't really know what is causing it. If I was doing it I would try and get hold of a proper MT75 release arm and bearing. Again, I have no idea why Richard didn't use the official one. Maybe when he bought the gearboxes they didn't come with a release arm of release bearing so he decided to save money by making his own bearing and fitting any release arm he could find. Or maybe the proper release arm was too long to align the cable with the hole that was drilled in the mounting plate. We are in undiscovered territory here In an ideal world it would be nice to run the engine while it is out, to test if the rattle has been fixed, as it would be annoying to have to drop the engine/gearbox again to try a different attempt. Not sure how you do that, maybe just connect the sensors up without using any of the engine mounts when the body is first dropped down.
I take it you have eliminated the cable as the failure point ? Can you still rattle the release arm or is it seized ?
I've asked him to post the details, alternatively he is on Facebook, Chris Mccormack. However, I have found some information that he sent me: Clutch Plate - Use EXEDY MZK2100 - £100 Pressure Plate - This is slightly confusing as he quoted LUK 623 3350 00. But when I googled that I got the full 3-piece clutch kit - £135. My spare clutch pressure plate has URB10009 0215 stamped on it so that is another option to search for. Release bearing - While you have it apart you might as well try the official MT75 release bearing. Google 500 0071 10. However there must have been a good reason why Richard made up his own bespoke bearings, I just don't know why. But at £20 it's worth a try. I will be interested in how you get on, my belief is still that the release bearing is meant to clip into the release arm, and ours aren't, hence the rattle. Let me know if you need any more information. I would also like to know how you manage to lift the car up
I know someone who has just changed his clutch and can tell you everything you need to know. Not sure he’s on here so I will get him to post a reply. Alternatively ‘wanderer’ has also just done his clutch so he might reply.
Hi, welcome to the Club. Unfortunately there doesn't seem to be an Area Secretary covering Cambridge. Perhaps you need to volunteer ? If you look at the Member map you will see there are 3 members relatively close to you. Jago, Gav888 and Leslie Walters. Might be worth Messaging them.
As it turned out there were only 2 of us so we just went and sat under the trees at Burghley House and talked kit cars My car started to run like a pig on the way home. Easy to diagnose when I looked at the trace of the lambda sensor in my log file: When I looked underneath. The lambda sensor wiring had come adrift and was scraping on the road. Soon one of the joins gave up the ghost. Quick fix
