nelmo
Posts posted by nelmo
  1. Its got a very small engine bay, virtually nothing at the back and that looks like the bodywork from a Radical - maybe some homemade thing designed for a bike engine?
    Did the seller not give you any clue? You originally said you thought 'the company had closed' - which company?
  2. Unless you've done some fabric work like that before and have all the equipment, I'd recommend buying it - SoftBits are very good (although slow) and the quality is amazing.
    I bought that marine vinyl for my doors and it wasn't cheap, so you're unlikely to save yourself too much...
    EDIT: ok, it seems to be much cheaper than I remember, although I cannot actually find the same stuff I bought...however, I'd still get it made for you. Unlike changing brake discs, for example, a roof does require some skill and it can look VERY bad if you don't have that skill.
  3. On 11/20/2023 at 1:48 PM, peter_m7uk said:
    This says to me that the IVA and MOT rules are different!
    Absolutely - IVA is the test that is also used for when, say, Ford want to introduce a new model. It is a much more thorough, demanding test than an MOT which is just a check for basic safety, really.
    My fog light also stays on if you turn the other lights off and on again - been through 3 MOTs with no problems.
  4. Not having any documentation is probably easier - tell them its rough age, you'll get a Q plate, smoke test for emissions at MOT, nice and easy.
    I sometimes wish I had kept the Q plate they first gave me for my car but, no, I had to insist on a new plate and now every MOT is a struggle to get through emissions.
  5. Do you have the GBS exhaust where the cat and exhaust are in the one piece? If so, that is fine for IVA. If not, read the manual - I don't recall there being any requirement for a heat shield but could be wrong. Also, if it is a very exposed exhaust end and it does get very hot (if you've wrapped it all the way along, that will happen), you'd probably want a heat shield for your own safety.
    People will tell you that you need to allow for the sharp edge on the sprung hook (if you have the GBS setup) that holds the exhaust end on the bracket but I didn't do anything and I had no problem (although I may have just been lucky?).
