Area Secretary
Everything posted by Andi
  1. Andi
    Starter Motor
    Does anyone know what part numbers/specs starter motors which will fit 2l pinto manual. Cheers Andi
  2. The Butty run is on this Sunday April 5th. http://www.butty-run.com/Hot-Rod.html Great bunch of people and some truly amazing cars there. I will be leaving the Mill on the Soar LE9 6QA at 09.15 if anybody is passing through. All dependent on the weather of course Andi
  3. Andi
    Grahams 2b
    Nice http://s630.photobucket.com/albums/uu29/gaz0571/
  4. Andi
    Modified Engine Setup
    Sounds like you could do with a home call. Are there any knowledgeable hoodies in your area?
  5. Andi
    Fuel Everywhere!
    Check the float bowl drain screws while carbs are on and check the common mistake of putting the fuel pipe into air intakes instead of fuel inlet. Other than that looks like a carbs off jobby
  6. I am not by no means a vegetarian, but the one and only place I will not eat meat is KFC. Its not so well publicised here in the UK as some other countries (I learned about it in Germany) but like agent zed says its the way they are reared. There are as many chickens as humans on the planet but no other is treated so badly and on such a huge scale. Here`s a quick video, and yes it is Pamela Anderson, but the rest of the birds dont look so good (not for the kids by the way) http://www.youtube.com/watch?v=PFgbHK6yP2g
  7. Andi
    West Mids Shows
    Dont know Gaz but it looks in trouble http://www.butty-run.com/images/2007%2003/...7-03-11-05.html
  8. Andi
    Bike Carbs
    Could be the mixture running a bit lean, in the past though whenever I have had popping/backfiring it has always been air leaking through the hoses (ie not making a good seal usually on the carb side as opposed to the runners side) Try spraying WD40 round the hose ends while its running, if the engine speeds up you have an air leak.
  9. Andi
    Oil
    Done 4000 miles since i had the car, the engine had been rebuilt maybe 1000 miles before that. Im going to do an oil change but as the topic says does it pay to flush and what flush is recommended? Thanks in advance
  10. Im playing guitar for a Punk band tonight, then theres an after party so heres my excuse in advance if I dont make it. Otherwise yes, and a good location.
  11. Andi
    Zero Pics Again
    Managed to get you page. Images are small but this is slightly better. Klik on piccys and enlarge, or klik on slide show. Andi http://s608.photobucket.com/albums/tt163/scrabster/ Most importantly, lovely looking car btw.
  12. ooops! didnt read that one
  13. Off a female friend Why Men Don't Write Advice Columns Dear Walter, I hope you can help me here. The other day, I set off for work leaving my husband in the house watching the TV as usual. I hadn't driven more than a mile down the road when the engine conked out and the car shuddered to a halt. I walked back home to get my husband's help. When I got home I couldn't believe my eyes. He was in our bedroom with the neighbor's daughter. I am 41, my husband is 44, and the neighbor's daughter is 22. We have been married for ten years. When I confronted him, he broke down and admitted that they had been having an affair for the past six months. I told him to stop or I would leave him. He was let go from his job six months ago and he says he has been feeling increasingly depressed and worthless. I love him very much, but ever since I gave him the ultimatum he has become increasingly distant. He won't go to counseling and I'm afraid I can't get through to him anymore. Can you please help? Sincerely, Sheila ****************************** Dear Sheila: A car stalling after being driven a short distance can be caused by a variety of faults with the engine. Start by checking that there is no debris in the fuel line. If it is clear, check the vacuum pipes and hoses on the intake manifold and also check all grounding wires. If none of these approaches solves the problem, it could be that the fuel pump& nbsp; itself is faulty, causing low delivery pressure to the injectors. I hope this helps, Walter
  14. Normous Newark M-E-G-A Autojumble is on tomorrow. Never been before but will take a run down there weather permitting. Chance of rain 30% in the morining. Hmm!
  15. http://shop.ebay.co.uk/items/__rivnut_W0QQ...;agid=857864798 As an alternative (if you ever need to remove panels)
  16. Andi
    New Area Sec W.w.w.m
    Nice one Gaz, Fancy a run out with your neighbours?
  17. Andi
    Build This Kit Car
    Nice build Steve
  18. Has anyone got any alternative maps other than on here http://www.cate1.co.uk/megajolt/mapping.php I have 2l pinto, kent fr22, ZX6r TPS carbs and megajolt V3. Thanks Andi
  19. Took this link off another site. Dont know if its been on here before, but its top notch. http://www.ne.jp/asahi/shift-down/austin/p...process7_01.htm http://www.ne.jp/asahi/shift-down/austin/data/download.htm
  20. Andi
    Monkeys
    Hmmm! Plenty of thought on that one. Maybe its like when a large group of you move on to the next pub and some dont.
  21. Andi
    Ramps.....
    Real nice mate methinks Ian........... Ive been sussed
  22. See you there Andi
  23. Andi
    Ramps.....
    Lol, I am into my 2nd week of a 10 week part time course in an introduction to welding. When I can manage to weld a straight line I could manage a delivery date of .........about April 2011
  24. Andi
    Ramps.....
    Ive seen these ramps some months ago and its these that have given me the inspiration to start a welding course at college. Andi
  25. Andi
    Cables
    After snapping my accelerator cable I read an article on the web about making/modifying cables. I got a pushbike brake cable with a barrel end (for bike carbs) then got the old sierra swivel type nipple that joins the pedal and drilled out the old cable in the shaft, inserted the cable then filled it full of silver solder (Maplins) which really seems to have held it but time will tell. I was wondering if anyone else has tried this?
