toriitom
Area Secretary
toriitom last won the day on December 20 2022
toriitom had the most liked content!
1 Follower
    Robin Hood 2B Plus with Cobra hoops
    HilaryThomas Ward
Contact Methods
  • Website URL
    http://
    Dundrod
  • Interests
    Anything with 4 wheels
toriitom's Achievements
Builder
Builder (2/6)
9
  1. Rawlplug make a rubber version that might suit you
  2. Over here there lots who dont
  3. I was thinking when you said you did some work on the column that if you had moved any parts of the column causing the knuckles to bind. To check if any parts of the column are causing your plight you could jack up the front with both front wheels off the ground and the bonnet removed, move one wheel from left to right and glance in at the column to see if any of the knuckles are causing the problem. HTH
  4. That was my understanding of the changes made in the rules. AFAIA that is what happens in any cars manufactured after 2013.
  5. Where does he work so that I know to avoid going there
  6. I thought the same
  7. I found a website quite some time ago that will let you compare the sizes of wheels and how such a change will affect your speed. Have a look at this and see if it will help you. Tyre size comparison HTH
  8. Did you try this guy https://www.facebook.com/Bathoscars/posts/exhaust-heat-shields-fabricated-to-any-size-and-with-personalised-logo/728478694227765/ HTH
  9. A switch is not just a switch. Switches come in two varieties, Normally Open and Normally Closed, so you need to ascertain what type you have in your car before you run out and buy one of the wrong type. I would assume that the brake light switch that is controlled by the brake fluid pressure would be a N.O. switch and it closes when the brake pressure activates it. Reed switches activated by a magnet come in both varieties so be careful about which one you use. I would be more inclined to use a micro-switch with the arm on it. These have 3 contacts giving the benefit of having both N.O. and N.C. contacts so should suit most users needs. Available from RS for under £5.
  10. I have an old 50ltr and an old 25ltr connected together as you describe and I use them as a receiver tank when I need lots of air
  11. toriitom
    Motorfest NI
    For those members who reside in N.Ireland and also for those visiting Motorfest NI has come round again. The event will be in 21st August 2022 at the Ballee Playing Fields in Ballymena. For further details see poster below
      • 2
      • Like
  12. toriitom
    Sad News.
    I did not know Bob but I am sure that he will be sadly missed by his close family and friends. My sympathies to you all.
  13. Have a look at caravan cupboard latches some of them operate the way you require HTH
  14. Just like mine.
